Old 10-17-2004, 01:33 PM
miverson332's Avatar
miverson332 miverson332 is offline
Master Tech Question???
Ok, since nobody helped me on the combustion question I went ahead and stripped the engine down to the block. I noticed a little bit of sludge, and alot of oil leaks coming from the base of the head where the gasket is. I immediately assumed that the head gasket was blown. Although, I think I ran into another problem. The top of cylinder one piston looks new, and had fresh oil pooling on it. Cylinder 2,3, and 4 are dry with burnt oil sludge melted to them. Does this mean that I may have a cracked block, or bad oil pump? The head itself seemed to be lightly lubircated, and in good condition. I don't seem to notice any water in the oil, but this looks bad. Any suggestion?
Old 10-17-2004, 05:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
What did the spark plugs look like? Do you have any pictures?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 10-17-2004, 07:42 PM
Autocratic_1st_Gen's Avatar
Autocratic_1st_Gen Autocratic_1st_Gen is offline
Re: Master Tech Question???
2,3,4 are normal, 1 sounds like it could have a leaking head gasket, bad rings, or worn valve stem seals.
i have a 91 Civic DX with 3x as much money in it as what i paid for it
i wish it was fast
here is my website
http://www.geocities.com/krustindumm/index.htm
Old 10-17-2004, 08:58 PM
Re: Re: Master Tech Question???
Is your avatar the headgasket you just took off?
ZC stuff
