Go Back   Automotive Forums Car Chat > Honda > RSX
Old 10-17-2004, 12:35 PM
rsxballa rsxballa is offline
head gaskets
im looking at a head gasket on clubrsx and i was wondering if its worth the $65 or so bucks it is. Good idea? or not
2004 rsx type-s
pearl blue
injen CAI
2 audiobahn 12s
Old 10-17-2004, 01:52 PM
SwiftAddictions's Avatar
SwiftAddictions SwiftAddictions is offline
Send a message via AIM to SwiftAddictions Send a message via Yahoo to SwiftAddictions
Re: head gaskets
I did not see any head gaskets, but I assume you are speaking about the 65 dollar intake gasket.
Anyway, it says they made it out of metal so it would heat the air coming in. I was under the impression that you wanted the air to be colder so you could put more air in and increase you compression, hence the cold air intake. But if you RSX is stock it says it will add some performance, and if it didn't I would bitch at them. I personally would keep lok ing and do some comparison shopping.
Light-wheeled Vehicles Mechanic, United States Army
[email protected]
Old 10-17-2004, 02:11 PM
Re: head gaskets
yeah.. the intake gasket.. my bad on that.
2004 rsx type-s
pearl blue
injen CAI
2 audiobahn 12s
Old 10-17-2004, 10:52 PM
mmont0's Avatar
mmont0 mmont0 is offline
Re: head gaskets
No, the intake gasket at crsx is NOT made out of metal. It's made out of plastic. It DOES lower the temperature of the air since the stock piece is all metal and it is supposed to give you a few more hp.
It wouldn't hurt to change it, but it requires you doing a lot of work to get to it - like taking off the header. I would suggest getting a new header as well if you're going to put that much work into just changing the gasket. A replacement header should be in the $300 - $500 range, depending on which one you get.
I would probably spend the cash on a header if I was going to go through all the trouble of replacing the gasket, but that's just me.
If you're just looking for a few more hp, just replace your stock intake, if you haven't already done so. It's probably a bit easier than taking your header off.
Originally Posted by SBallerk2
yeah...I thinking of trading in my '94 Lude VTEC for an RSX-S
Old 10-18-2004, 01:49 AM
Re: head gaskets
Ah, I see now, the description is worded wierd. Looking at the photo helped a lot too.
[email protected]
