Old 10-17-2004, 11:01 AM
daveyfigs daveyfigs is offline
My dashboard lights
I know it's been discussed already here, but in my case, the only ones giving me trouble are the dashboard lights including the radio and the a/c ones. I checked already the fuses, everything is o.k. Please give some imput, it's been three years in total obscurity
Old 10-17-2004, 11:03 AM
By the way, it's a 96 Lumina.
Old 10-17-2004, 01:52 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: My dashboard lights
I'm gonna say it's a problem with the dash dimmer switch.
Old 10-25-2004, 11:43 AM
dannas dannas is offline
try unplugging the ...
under the hood light and recheck the inside fuses. if you plug my under the hood light in it blows all the inside dash, overhead, and all those lights and what nots!
Old 10-25-2004, 02:21 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I would check the headlight/interior light dimmer switch first, as well as the interior light fuse.
Old 10-25-2004, 09:54 PM
I've checked everything...nothing wrong, still in obscurity.
Old 10-25-2004, 10:26 PM
cadgear's Avatar
cadgear cadgear is offline
Not to be left out, check the bulbs of the questionable units. Hook them up to fused battery power and see what you get.
Old 10-26-2004, 08:38 AM
Look for a broken ground wire (especially if an aftermarket stereo or something was installed. If you can get a wiring diagram, you could chase it, or supply a known ground shunted to it for testing.
Old 10-26-2004, 08:58 AM
I took off the headlights/dimmer switch off, then put a wire from power to the dashboard lights cable and it works. So maybe is the switch?
Old 10-27-2004, 10:31 AM
GTLumina GTLumina is offline
Dimmer Switch
The headlight switch assembly was one of the first maintanance items I had to perform on my '97 Lumina. It was still under warranty. I appears to be a common problem with these cars.
