Old 10-17-2004, 09:24 AM
C5Longhorn's Avatar
C5Longhorn C5Longhorn is offline
Broken Seat Recliner Handle
Hi. I'm a new member and this is my first post. I just discovered this site and have a question about a problem I'm having with my passenger seat. The reclining handle broke off at the shaft mounted to the actuator. I've heard there is a better part available that I can buy and upgrade to. I've also seen ads on Ebay for a fix to the broken shaft. It reuses the old handle and basically attaches over the broken shaft with some set screws.
I was wondering if any members have had this problem and if so, what did you do to fix it? Also, how happy are you with the course of repair?
Thanks and I look forward to learning alot from this site!
Rick S.
'99 Chevy Blazer LS-Daily Driver - K&N Air Filter
'02 Mil. Yellow Z06-Vortex Rammer, FLP LT Headers, MTI LS1 Edit programming, Kirban Shifter, NGK TR-55 plugs and Taylor 409 wires, MOMO shift knob, Baer Eradispeeds, Ken King Interior accessories, APC headlights and PIAA 1100 Foglights, lowered, !CAGS
Old 10-17-2004, 10:19 AM
dogtired78 dogtired78 is offline
Re: Broken Seat Recliner Handle
I found a complete repair kit at my local Federated Auto Parts. It's got a steel shank that fits over the broken off actuator rod and a screw you drill in crosswise. You don't have to reuse the handle.
This is a common fatigue problem on blazers. Both seats on mine were broken. The only drawback is that the kit is expensive, around $38.00
Old 10-17-2004, 05:51 PM
C5Longhorn's Avatar
Thanks for the response. Are you happy with this fix?
Rick
Old 10-18-2004, 07:46 PM
C5Longhorn's Avatar
Nobody else has had this problem?
Old 10-19-2004, 12:42 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Go to the wrecker and get a replacement and replace it.
Simple as that. And make sure the person leans forward before using it to stop it from snapping next time.
A lot of morons liek to push back while they pull up the lever.
Old 10-23-2004, 03:54 PM
C5Longhorn's Avatar
I would like to order the parts from GM parts direct. Does anyone know how to find out what part # corresponds to what color?
Old 10-23-2004, 08:03 PM
BlazerLT's Avatar
AF -Advisor
I would give them a quick call.
Old 10-24-2004, 01:37 PM
C5Longhorn's Avatar
Re: Re: Broken Seat Recliner Handle
Thanks. They won't take phone calls. I've emailed their customer service but don't know when I'll get a response.
Old 10-25-2004, 11:06 AM
mw2 mw2 is offline
You can look at the following links for possible fixes: http://www.gmseatfix.com or http://www.wittydeals.com/product_in...76f6e053552a08 .
You can also do a search on the word recliner on this forum to get more information. Another link that is helpful is: http://bbs.off-road.com/ubbthreads/s...53&Search=true .
I had a 2000 Blazer where the passenger side broke and I fixed it under warranty. I sold that Blazer and bought a 1998 Blazer (two months ago) which had both sides broken. Was going to order one of the alternative fixes but on a lark, I email customer assistance center at http://www.gm.com/ . I couldn't believe it but guess what, they fixed both sides free. The service manager that I worked with was very helpful.
I emailed two times to Gm Parts Direct. The first time they emailed back in three days. I'm still waiting for the second time - it's been a week.
Hope this helps. Good luck.
Old 02-22-2005, 03:08 PM
JoshBarber JoshBarber is offline
just ordered mine from WittyDeals. Thanks! Do they come with install instructions?
Old 02-22-2005, 03:40 PM
TonyMazz's Avatar
TonyMazz TonyMazz is offline
I ordered mine from gmfixseats and they take a conventional handle and install a sleeve that will fit over your old shaft, then there is an allen screw that will tighten it securely.
My seat handle broke, and a junk yard would not have fixed it, as the shaft was broken down the middle, as they have a slot. I suspect that is what could have happened in your case.
To have GM repair it would cost you about $150 bucks as they rip out the old mechanism and install a new one...the same white metal as the old one. You are doing the most cost effective repair with this handle.
Old 02-22-2005, 04:24 PM
Re: Re: Re: Broken Seat Recliner Handle
yeah, the one I bought is the same. if you look at the link it shows where they normally break off. Thats where mine broke. A used one wouldnt have worked, and probably wouldve broken shortly after anyway. Its obviously very common!
Old 03-02-2005, 02:38 PM
Re: Re: Re: Re: Broken Seat Recliner Handle
just a heads up.......
FYI-
I just saw today that AutoZone carries the same one I purchased from WittyDeals.
Old 03-02-2005, 03:48 PM
toenailclippers toenailclippers is offline
Send a message via AIM to toenailclippers
dude, just use a pair of vice grips. they are about 10 bucks, andthey are always in the truck if you ever need them. just adjust the tension to wrap the middle ofthe grips' aronud the old shaft and...WALA!! new seat reciner handle. ive had a pir of vice grips on my 98 blazer for 5 years and had NO problems whatsoever
Old 03-02-2005, 04:16 PM
Thumbs down Re: Re: Broken Seat Recliner Handle
if I didnt care what it looked like, that'd be a good fix. but since I prefer a decent looking vehicle....a couple of bux for a handle fix is fine
