Old 10-17-2004, 08:20 AM
air3pt air3pt is offline
Send a message via Yahoo to air3pt
Rear end knock during takeoff
Every so often I get this rear end knock or two when I first take off.
Does anyone know what would cause this to happen?
Old 10-17-2004, 08:38 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Rear end knock during takeoff
It could be almost anything, Damaged ring gear,pinion gear,axle,carrier(could even not be rear and be your driveshaft) but if I was a betting man I would say that you have a gasket leak and fluid is far too low or that you haven't changed the fluid in a couple of years and the viscosity has gone to sh*T. Also welcome to the Forum. If you need anymore info just let me know
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-17-2004, 03:38 PM
Re: Re: Rear end knock during takeoff
Thanks.
With what you said about fluid change it has been a while and I will have that checked. Should have thought of it, but glad you did.
Thanks again.
Old 10-17-2004, 03:41 PM
FormulaLT1's Avatar
Fight the powwa!!!
N.P.... Let us know how it turns out.
John
Old 10-17-2004, 10:26 PM
BiggyD's Avatar
BiggyD BiggyD is offline
U-joint?
Black '97 Trans Am WS6 Smoked!
Rice is the perfect side dish!
Old 10-17-2004, 10:32 PM
FormulaLT1's Avatar
Fight the powwa!!!
Yeah, could be u-joints but when I mentioned driveshaft I was kinda including or at least try to include all driveshaft part's because a driveshaft unless hit or trying to manage a severe amount of torque will not break. Also its probably not the u-joints because they said it was random where as a u-joint will cause a clunk when put into gear and when you start out under all kinds of throttle response.
Old 10-17-2004, 11:11 PM
BiggyD's Avatar
true that.
Old 10-19-2004, 07:19 AM
savagewolf savagewolf is offline
i say its the tranny mount.
A great man once said "I reject reality and substitute my own" ...this is the key to a happy life.
Old 10-19-2004, 07:22 AM
FormulaLT1's Avatar
Fight the powwa!!!
That is another possible cause. I was thinking of adding that after I posted. Its a very commen problem with 3rd and 4th Gens.
Old 10-20-2004, 09:57 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
hmmm. well i had this same issue and rebiult the rear end, and tranny. its a trac bar bushing, actually i put in a aftermarket trac bar it had new bushings in it. it fixed it, an older sports car with good torque and alot of miles, the bushings dry rot and usually fall out like mine did, i have seen 3 other 3rd gen camaro and firebirds do this same thing and it has been the trac bar bushings.
Old 10-21-2004, 03:21 AM
FormulaLT1's Avatar
Fight the powwa!!!
Good to know, I've never had that problem with my 4th Gen and I never owned a 3rd Gen but sounds like it could be whats going on. Hopefully we will find out what actually caused it and how he made it go away soon.
Old 11-04-2004, 04:07 PM
orionwolf orionwolf is offline
I had this same problem with my 96 T/A
The cause was broken transmission mounts, when I would take off, the transmission would bang into the housing, you might have the same thing.
Old 11-06-2004, 08:44 AM
To all those that said Tranny mount you were correct.
Took about 20 minutes to fix and all is well.
Thanks for the input.
