Old 10-17-2004, 03:44 AM
bumperjack bumperjack is offline
Send a message via Yahoo to bumperjack
Question 98 silverado wiper problems
98 silverado wipers quit working,is it true that you can remove the circuit board and solder the connection?
Old 10-17-2004, 07:05 AM
Jeremy-WI Jeremy-WI is offline
Re: 98 silverado wiper problems
yes you can, usually you can just reheat the old solder where the connector interfaces the circuit board
Old 10-17-2004, 07:57 AM
thanks!
Old 10-17-2004, 08:23 AM
Re: Re: 98 silverado wiper problems
thanks jeremy for the info,one more question,what is this circuit board and what does it do? is it for the intermittent function?
Old 10-17-2004, 09:51 AM
Craigvalk Craigvalk is offline
Re: Re: Re: 98 silverado wiper problems
Hi there, I am not Jeremy, but yes, it's for the intermittent function as well as the others. Common problem, you'll be all set if you re-flow that solder.
Craig
Old 10-17-2004, 04:30 PM
01max 01max is offline
wiper module
you might call your gm dealer because there was a recall on the wiper module for quite a few years.
Old 10-17-2004, 11:47 PM
skipr skipr is offline
My 98 Z71 has a wiper problem. don't turn on, but if I reach my hand out the window and pull on the one driver side wiper, they start going. After I shut them off they don't stop. So I reach out and do the oppisite try to hold the wipr on it's down cycle, and they stop but not always in the full down postion. What is this wiper motor thinking? I have learned to live with it. In southern California rain is not very offen. In fact it would be a desert if we didn't steal our water from the Owens Valley up north.
Old 10-18-2004, 04:42 AM
[dude,all you have to do is resolder the 6 points where the plug attaches to the circuit board! its so easy my ol lady could do it !i didnt have a clue till i joined this forum, this is a great place to learn!
Old 10-18-2004, 04:45 AM
tried reheating old solder but had to add 50/50
Old 10-18-2004, 04:47 AM
now the wipers work like a charm,thanks for all the help
Old 10-18-2004, 09:32 AM
Thanks, I can solider quite well. And yes these are excellent forums, Alot of nice helpful people. But once and while you run into someone that calls you a girly with sand crouch.
