Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-17-2004, 01:36 AM
PK55 PK55 is offline
Send a message via AIM to PK55 Send a message via Yahoo to PK55
HELP!!! No brake lights on 87 Camry!!!
Hey guys...you've been right before so I'm looking for your help agian!
On my 87 Camry the TOP stop brake light won't come on. I've changed the fuses and the bulbs and still no luck. The bottom light on the harness works (constant light) but the TOP brake light doesn't...???
...Thanks in advance...
PEACE
Old 10-17-2004, 10:24 AM
yotatechie04's Avatar
yotatechie04 yotatechie04 is offline
Send a message via ICQ to yotatechie04 Send a message via AIM to yotatechie04 Send a message via MSN to yotatechie04 Send a message via Yahoo to yotatechie04
Re: HELP!!! No brake lights on 87 Camry!!!
If your third brake light won't come on, you might want to check the electrical connections to both the bulb and the wiring harness to make sure that they aren't loose.
1994 Pontiac Grand Am GT - 3100 V6
1992 Chevrolet Lumina Euro - 3100 V6
1997 Ford Escort - 2.0 I4
"She only squeals when she's wet..."
Old 10-18-2004, 04:19 AM
This is actually the main brake light. It has two lights on the harness. the bottom is the night lights, no brakes, and the top is the brake light itself.........
Old 10-19-2004, 08:06 AM
dariusfan dariusfan is offline
Re: Re: HELP!!! No brake lights on 87 Camry!!!
I had a similar problem. I fixed it by removing the wire which attaches the (I think black and white striped ) wire to the socket assembly. Mine did not have a lock washer under the screw and with time and vibration it would loosen up just enough to create a problem. It never got really loose but I found that the connection would get warm and it actually deformed the plastic due to the heat. I used a small file to clean off the part of the connector that the screw comes in contact with and put a lock washer under it. Problem went away. The light icon on the dash always seemed to come on after I had slammed the trunk lid (usually at night). But then the next morning when I had time to work on the problem everything worked because it had cooled down over night...
Good luck with your light.
Paul
Vancouver
Old 10-26-2004, 10:33 AM
Thanks Paul...I'll check it out and post back bro...
PEACE
Old 10-27-2004, 11:06 AM
rwood13 rwood13 is offline
check the ground as pk55 said, I have a 88, if you have an indicator on the dash that lights when a light is out, trace the light wire harness in the trunk, you will find a box (mine was yellow), consult a wiring diagram, jumper the brake light wire around the box, if it works the box is bad, it is a sensor box for the rear lights, it burns out componets inside from time to time
