Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-16-2004, 10:35 PM
newcamry4me newcamry4me is offline
Send a message via AIM to newcamry4me
Aftermarket air filter problem....
my friend put on an after market airfilter for me and now it is having problems with the master air flow sensor, does anyone know how to fix or where i can get a circular master air flow sensor? please help....
Old 10-17-2004, 02:05 AM
Bossman Bossman is offline
I think you might have meant Mass Air Flow sensor. What year Camry? I put a K&N air filter in my 03 4-cyl. Camry with absolutely no problems whatsoever. It's the direct replacement for the OEM filter; not the open filter cone type. Maybe something was knocked loose during the installation of yours and you might want to retrace each step to try to solve the problem.
Old 10-20-2004, 12:28 AM
dschwartz46 dschwartz46 is offline
Re: Aftermarket air filter problem....
I know someone who has ruined their mass air flow sensor by using too much cleaning solution in their K&N filter. Did you do anything to the filter before installing it?
Old 10-20-2004, 09:04 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
I clean the oil-wetted filters by using the cleaning solution first, then rinsing, then using a dilute solution of dish-washing liquid in water to soak the filter to remove both dirt and the residual cleaning solution (alot of additional dirt comes off the filter when I do this). Then I rinse the filter with water and let it dry for a day before I re-oil it with a minimum of oil.
Old 10-20-2004, 06:23 PM
Bmaintz Bmaintz is offline
I use an Amsoil filter system in my '92 Camry with no problems at all... I use the wetting oil sparingly where it is just tacky to the touch....
Bob
South Mississippi
92 & 94 Camrys
Old 10-20-2004, 08:12 PM
Brian R.'s Avatar
Resident Chemist
Both AMSOIL and TRD are great filters. IMO, the cotton TRD filter is a better element.
