Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-16-2004, 08:17 PM
lilpud lilpud is offline
Send a message via AIM to lilpud
Unhappy help with clutch
i have a 02 v6 mustang and sometimes i have a little play with the clutch petal, as in like it is loose and you can move it front to back like 1/2 to a full inch. What could this be. do i need a new clutch or what??
Old 10-16-2004, 09:51 PM
91notchback's Avatar
91notchback 91notchback is offline
Send a message via ICQ to 91notchback Send a message via MSN to 91notchback
i dont think thats really a problem its just alittle bit of play at the top i think most all cars have alittle play in the cluch
Old 10-17-2004, 12:52 PM
Mendari Mendari is offline
Re: help with clutch
You may want to follow the factory instructions for lubricating the clutch cable. But I don't think you need a new clutch.
Old 03-12-2005, 02:36 PM
jerskagg jerskagg is offline
Question Clutch Problems
I have a 2001 Mustang and am experiencing the same problem. I was told by a mechanic to replace my clutch quadrant. I replaced that and installed a firewall adjuster. Let's just say nothing was solved. Not only do I have play in the clutch but I almost have to let it up all the way for it to start moving the car. I just had a new clutch put in about nine months ago. Is this the same with yours?? Any suggestions??
Old 03-13-2005, 04:51 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Re: Clutch Problems
Now try adjusting your fire wall adjuster.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 04-14-2009, 10:02 PM
burntrose2 burntrose2 is offline
i am sorry for your wasted effort, but there is a ratcheting mechanism used to calibrate clutch cables to the clutch itself. this apparently has adjusted itself too far for some reason...simply resetting the ratcheting system and forcing the clutch to readjust itself should solve the problem...however i would suspect another problem elsewhere...possibly leading up to a worn clutch disc...i don't care if it's 2 days old it can be worn out
