Old 10-16-2004, 08:02 PM
wes5314 wes5314 is offline
1985 buick park ave won't start
car will turn over but want start. has new distributor cap and new rotor,new plugs, plugwires,.I have checked the timeing chain and it its in time. checked the injectors and they pulse. had the cotrole module checked and turned out to be fine. I dont have a fuel pressure gauge , but when i push the shrader valve on the fuel line it shoots out. Kinda lost, any help would be greatley appreciated.
thanks.
Old 10-17-2004, 09:57 AM
yogi_123rd yogi_123rd is offline
Re: 1985 buick park ave won't start
Check for spark: If none, it's usually a sensor bad: the crankshaft position sensor and/or the camshaft position sensor.
Old 10-17-2004, 10:23 AM
Re: Re: 1985 buick park ave won't start
I did it has spark.
Old 10-18-2004, 03:08 PM
parkavenuechrome parkavenuechrome is offline
What motor is in your 85? remeber, just because you have spark doesn't mean its enough? Under compression if your spark is weak, it won't fire.
