Old 02-18-2002, 01:00 PM
kingmike kingmike is offline
Send a message via AIM to kingmike
Dohc Zc
Just swapped out the stock Si motor in my 89 CRX Si with the DOCH ZC. We re-built the motor, bored .5, used integra pistons, stock si rods (good up to 200hp from what I understand), and everything is going smoothly except for one thing, whenever I first start the car a cloud of white smoke flows from the exhaust. It also happens when I first rev the motor. Any suggestions?
Old 02-18-2002, 06:28 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Its called water vapour, or steam not smoke.
If its only present upon start up, and when the air temp is cold, then dont worry about it. Its quite normal.
If its there all the time, then you need to worry. It could be a blown head gasket.
Old 12-31-2003, 09:39 AM
SlamedownCivic SlamedownCivic is offline
Send a message via AIM to SlamedownCivic
Re: Dohc Zc
Im rebuilding my DOHC ZC what can i use to replace the crank rods an pistons?
Old 12-31-2003, 03:37 PM
F23A4Racer750IL F23A4Racer750IL is offline
Re: Dohc Zc
how much did the Si Rods and Integra pistons cost ya?
Old 01-01-2004, 10:27 AM
Re: Dohc Zc
b-series pistons ina D-series block?
Old 01-05-2004, 06:26 PM
Smokn91HB Smokn91HB is offline
Send a message via AIM to Smokn91HB
Re: Dohc Zc
It can be done as long as the bore is the right size
Old 01-05-2004, 06:34 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
Re: Re: Dohc Zc
89-95 there were D series Si's. Before that they were EW's.
Old 01-05-2004, 09:49 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Dohc Zc
Doesn't oil that's burned up during combustion of the gas also produce white SMOKE?
Being an older engine, and custom bored out I could see it possibly burning up some oil when first cranked from a cold state.
Maybe I'm way off base on that though.
kingmike : does the "smoke" have an odor to it like burning oil or something burning, or not at all?
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 01-05-2004, 10:23 PM
Re: Dohc Zc
im in the process of rebuilding my DOHC Zc, Si Crank an Rods an new bearings..i was gonna buy a stroker kit but my funds got kinds low after bills.i hope to have her up an running by friday.
Wanted I Need A Neon Sport DOHC Cylinder Head 1997-Dodge-Neon Cars/Parts for Sale/Exchange 1 08-25-2009 12:23 PM
engine swap 2.0 dohc to a 3.0 dohc? k-townracer 1st Gen 95-99 2 04-20-2007 04:08 PM
92 SC2 DOHC Header on 96 SC2 DOHC Dale_San_Diego SC/SL/SW 3 02-10-2006 04:12 PM
2nd Hydro ZC DOHC fit 1st gen ZC DOHC?? CRXsiZCpa '88 - '91 Civic | CRX | Wagon | Shuttlee 1 10-10-2004 02:08 AM
sohc to dohc Pharty012 Jetta/Vento/Bora 3 07-11-2002 01:18 PM
