87 camero headlight problems
i have an 87 v6 camero. my stero went out when i was down town and for a second i thought my car stopped running so when i got home i had my dad and brother look at it. i found out that my wippers nor my headlights were working. my dad thought it may be the light switch (WHICH IS NOT ON THE STERING WHEEL) so i bought a new one, then found out it was not that. so he looked at the fuses but none of them were bad so the next thing we thought was maybe it was a relay switdch which it wasn't so can anyone tell me what may be wrong with my baby??
Re: 87 camero headlight problems
battery/corroded terminal problem in your camAro is a possibility
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later. 194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies 179.75 RWHP, 204.52 RWTQ ON ITS WAY: MORE R.I.P. Andy 87 Benz 190e - DD 01 EX250 - still gotta get my license for this thing |
I just couldn't see it not being a fuse or relay...possible ground connection.
97 Z28 C.A.I. Edelbrock shorties,all free mods,Borla's,MSD,LT4 timingchain, 1.6r/r,LT4 cam, NGK,p&p heads,ported maf ,52mmTB adj fuelpressure reg.,373's,pcm tune by pcmforless, all poly bushings,spohn t/a, s/t brace, etc. What I don't have..no egr no air pump and no cats Well dip me in chocolate and throw me to the lesbians!!!!!
does your dad or bro, or yourself, have a test light??? have you tested the circuit back down the instrument panel? i would test for power to the circuit, when you find the point that has power on one side, and no power on the other, youve found the problem.
Chevrolet Camaro - I enjoy beating the hell out of people http://www.automotiveforums.com/vbulletin/showthread.php?t=68052 |
welcome to the forum Camaro chic
Really sounds like a blown fuse.. Ide double check your power acc. fuses.. And than, as 89Iroc mentioned, use a test light to test for power at both sides of all the fuse terminals.. There should be power to one side of the fuse terminal.. What are you running for a stereo? factory? Do you have subs/amps hooked up?
1991 Camaro Z28 |
It's pissed off at you for spelling its name wrong.
maybe
check fusible links on both sides of links. pulling on them isn't the way to test them
