Old 10-16-2004, 06:09 PM
wufpak18 wufpak18 is offline
off road Y pipe Q's
Need help on exhaust decisions. I am wondering if an off road Y pipe will bolt directly to my stock headers. All I can find is MAC headers with the off road y pipe with it for my 96' trans am. I can't find the off road y pipe by itself. Does anyone know a website or a dealer where i can by an off road y pipe and can it bolt to my stock headers?
Old 10-16-2004, 07:35 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: off road Y pipe Q's
One question first are you planning on getting rid of all the cats?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-17-2004, 11:23 AM
I am thinking about it.
I know a guy who has a SS and put an headers, off road y pipe, and loudmouth on his car and it sounds sick nasty.
I would probably end up with no cats.
Old 10-17-2004, 11:32 AM
FormulaLT1's Avatar
Fight the powwa!!!
Well then thats easy you just need to get a header system and Y- set -up for a 93-95 (not Cali car though because 95 Cali F-boys got extra cats) and will need to cut out rear cat or gut it and have the Y-pipe welded in place. Also if you plan to go long tubes instead of mid or shorties which normally come with Y-pipe. You can look into buying a Hooker,Pacesetter or SLP off road y or You can have a fabrication made up at any local Exhaust shop for usually under $150 -$200. Don't forget your going to need O2 simulater(can't spell correctly right now but you know what I mean)
Old 10-17-2004, 11:49 AM
Having no cats will be illegal, right?
Old 10-17-2004, 11:50 AM
FormulaLT1's Avatar
Fight the powwa!!!
Yup(sorry I had to do a edit I read it too quickly before and thought you said legal instead of illiegal), If your looking to get away with it while removing some back pressure. I would get rid of the 2 forward cats and just run one like was used on earlier lt1's and this should pass because it passes on earlier cars.
Old 10-17-2004, 01:27 PM
FormulaLT1's Avatar
Fight the powwa!!!
Ttt
Old 10-17-2004, 02:10 PM
what header/y-pipe system would you recommend?
What would be best buy?
Old 10-17-2004, 02:17 PM
FormulaLT1's Avatar
Fight the powwa!!!
Depends on which route you want to go.
If I was looking for a cheap set up but that provided very good number's for very little money I would go for Pacesetter's Mid's which includes the Y-Pipe and the only things extra you will need is thread locking compound and better gaskets than the one's that come with headers cause those one's suck. I recommend GM replacement Gasket's.
2. If you have some money to throw around but still not the most expensive I would go with Hooker Long Tubes. USe there optional Y or I also believe Pacesetter LT Y- will work and same thing with gasket's and Locking compound
Hooker's are known for being one of the best on the market and Pacesetter have had good and bad reviews but I have had very good luck when it comes to dealing with them and the tone is pretty damn good.
P.S.- Keep in mind to call a exhaust Shop before hand and make sure they can Weld your exhaust the day of the install. As you will need to have the Y-pipe welded to the Cat.
Old 10-17-2004, 11:46 PM
BiggyD's Avatar
BiggyD BiggyD is offline
Is it bad to run no cats without O2 sims? I know it turns the check engine light on.
Black '97 Trans Am WS6 Smoked!
Rice is the perfect side dish!
Old 10-17-2004, 11:48 PM
FormulaLT1's Avatar
Fight the powwa!!!
The rear O2's don't have any control over A/F mixture , The only purpose they have is to make sure that your cats are filtering out emisions. So to short hand it no. Although I would not want to have my check engine light on all the time
Old 10-18-2004, 12:01 AM
BiggyD's Avatar
yeah I don't like it being on, but it's like 80 bucks for O2 sim. oh well.
Old 10-18-2004, 08:08 AM
savagewolf savagewolf is offline
correct me if im wrong but isnt the O2 sim just a resistor placed in the sensor. all it is on mine is a 2200 ohm resistor . but then again mine's a 90
Old 10-18-2004, 08:10 AM
FormulaLT1's Avatar
Fight the powwa!!!
I believe its more than that because if the O2 sensors stay stationary for any extended period of time that sets off the Check light as well.
Old 10-19-2004, 12:08 PM
koeb$ koeb$ is offline
Send a message via AIM to koeb$
u can get a hedman full exhasut system for lik $800 from jegs
84 TA- 350 bored
dynomaax shorty headers
custom 3" exhaust
electric exhaust cut out
holley 600 cfm carb
340+HP
cam?
97 jetta
white 15" bbs wheels
2 JL 12W3's and 2 JL 500/1 amps (for sale)
