The rear brake lights are my 95 Camry are not working. Thought is was a broken wire. Found some broken wires near door hinge. Looks like it slowly degraded till an open. Anyways, fixed the wires. Still the brake lights do not work. The top center brake light works, just not the right or left near the tail lights. Also, the "brake light out" dash indicator is also on. Reading through other posts thought it might be a blown sensor. But, I cannot seem to find the sensor to wire around it and check. Any advice would be much appreciated.
Re: 95 Camry brake light not working
Since there is a light functioning and not others on the same circuit, it is likely that the problem is in the harness associated with the lights that are out. Nothing else I can find will preferentially affect these over the hi-mount light.
Just for the hell of it, did you check the bulbs? |
