Old 10-16-2004, 05:37 PM
ramput ramput is offline
what did i miss?
95 astro vin w... new fuel pump,filter,cpi assembly,correct pressure..she will start with some fuel injector cleaner down the throttle body,,no trouble codes either!would greatly appreciate any sugestions
Old 10-16-2004, 07:43 PM
tableman tableman is offline
If it will start when you put injector cleaner down the TB, it sounds like you are not getting fuel to the injectors. I have never change a fuel pump in a Astro, but by the pictures in my Haynes it looks like you have 3 fuel lines, a Feed line, a Return line, and a Vapor line. They all look the same size, is it possible to mix up the feed line with the return line,
Just a thought
