Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 10-16-2004, 05:11 PM
89tracerman's Avatar
89tracerman 89tracerman is offline
Fluids
what type of fluid is used for the hydraulic clutch? i know its brake fluid but at
Napa they asked me if it wanted silicon or non silicon fluid, and i was like
my cardomain
Old 10-16-2004, 11:05 PM
D3rELiC's Avatar
D3rELiC D3rELiC is offline
Re: Fluids
i think silicon clutch fluid is for the fan clutch or somethign like that
Old 10-16-2004, 11:15 PM
Re: Fluids
so DOT 3 or DOT 4 and whats the difference? the one it gots its gray and its on the "low" mark
my cardomain
Old 10-17-2004, 01:55 PM
fcdriver fcdriver is offline
Re: Fluids
Ah it's been a while since I've dabled with dot but from what i can remember dot ratings are the boiling points, freezing points, fluidity( if thats a word). The best I can do for the explanation of brake fluid is this... brake fluid needs to be able to have a high boiling point, low freezing point, lub the seals in the brake system ie. brake cylinders, and it will absorb water if the lid is left off for a long time. The higher the rating the better the fluid type.
Old 10-17-2004, 08:12 PM
Re: Fluids
what if i have DOT 3 and i add DOT 4 or it has DOT 4 and i add DOT 3 will it mess it up or will it work. cuz i dont know which one it has.
thanks
my cardomain
Old 10-17-2004, 10:35 PM
Re: Fluids
Again I could be wrong but from what I can remember it's not a good idea to mix dot fluids, someone chime in here to correct me if I'm wrong. But it can't hurt to remove the old fluid and put new in just for preventative maintaince.
Old 10-18-2004, 12:11 AM
Re: Fluids
how can i do this?
my cardomain
Old 10-18-2004, 12:20 AM
Re: Fluids
You can loosen the bleeder screw and allow it to gravity drain or pump it out but you will have to bleed the clutch after you put new fluid back in it.
Old 10-18-2004, 03:14 AM
J-Rat's Avatar
J-Rat J-Rat is offline
Send a message via AIM to J-Rat Send a message via MSN to J-Rat
Re: Fluids
DOT ratings are boiling points. Its never REALLY right to mix them, but for your clutch system, your fine.
1988 10th AE Edition TII
More mods then you have.
