Old 02-18-2002, 11:10 AM
i_rebel i_rebel is offline
Banned
Send a message via AIM to i_rebel
Complete system rebuild . . .
I want to completely revamp the braking system in my car.
Without having done any research to know if it'll work or if it's feasable, I've decided on what I want:
Larger rotors (slotted & drilled) at the front of my car . . . with some combination that'll result in brake hardware that overall is more powerful, and yet much lighter than the stock setup.
I want do create some ductwork for cooling of the brakes . . . particularly the front . . .
I want to ditch the ABS TOTALLY . . . I want all of the components out of the car . . .
Who could I contact about this? Is there a brake specialist somewhere? Or would I have to look for someone that might have done work on the braking for race cars?
Please advise
Old 02-18-2002, 02:21 PM
Someguy Someguy is offline
Send a message via AIM to Someguy
For braking systems check out:
http://www.brembo.com/
or in particular:
http://hp.brembo.com/brandlist.asp?E...9&PageNumber=1
although I only see parts for the newer G20s. You may have to call to find out more.
Another good one is Baer/Alcon:
http://www.baer.com/
and of course Wilwood:
http://www.wilwood.com/
But be ready. A good set of calipers will run you at least $1k to get in the door, and over $2k for the "middle of the road".
Simplying pulling the fuse will disable the ABS on most cars. To completely remove the system will require a fair ammount of work though. You have to remove everything, then redo the plumbing. That can be pretty difficult since you are dealing with the hardlines.
To duct the brakes you will need to either remove dust shield or modify it. You can high temp flex hosing, or even buy used brake ducting from race teams. You want the duct to be aimed right at the middle of the rotor so the incoming air goes though the vents so the rotor is cooled evenly. Just pointing it at one side of the rotor will warp it. For even more cooling you can run a second duct to the caliper, although that is probably over-kill.
Old 02-23-2002, 03:19 PM
texan's Avatar
texan texan is offline
Writer Mod
And why would you want to disable your ABS? That's almost certainly going to increase you braking distances and will definitely increase the chances of losing control of the car under braking.
'03 Corvette Z06
'99 Prelude SH
complete engine rebuild 20zetechzscort ZX2 4 05-01-2007 11:52 PM
Delorean Brake System Rebuild hifeverz DMC-12 0 05-22-2004 12:36 PM
where on earth i can buy the complete system airconditioning for my honda civic SI 92 TheReef '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 11-24-2003 04:51 AM
Complete Engine Rebuild and Turbo for 1993 VTEC Sinistral Prelude 1 09-09-2003 01:07 AM
obc complete system for sale and more fporro 3 Series 0 06-24-2002 11:55 PM
