Old 10-16-2004, 04:14 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Wheels sagging in the back......Very akward
When moving cars in my drive way at night, I drove my mom's camry behind mine with the headlights on and my back wheels looked bent. They werent' "l...l" like normally, but they were "/...\" I just got new tires on and I know that this ain't good for the tread. Darnit, just when I thought things were looking up, another problem arises. What the hell do I do?
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 10-16-2004, 04:26 PM
Hybrid1990crx's Avatar
Re: Wheels sagging in the back......Very akward
get an alignment.
Old 10-16-2004, 05:07 PM
Shaguar47's Avatar
I didn't think the back of cars needed alignment though? I thought it was just for the front only.
Old 10-16-2004, 11:29 PM
93_R/T_TT_Stealth's Avatar
93_R/T_TT_Stealth 93_R/T_TT_Stealth is offline
Send a message via AIM to 93_R/T_TT_Stealth Send a message via MSN to 93_R/T_TT_Stealth Send a message via Yahoo to 93_R/T_TT_Stealth
sounds like you gotta recamber the rear suspension
Old 10-17-2004, 05:00 AM
anthony90si anthony90si is offline
take a look at the bushings. i bet they are worn out , whatever is left of them...
Old 10-17-2004, 01:32 PM
Shaguar47's Avatar
When I got hit in the rear end, the mechanic told me that I had to replace the bushings but that was only cause they were creaking every time the back end leaned. I looked at them and they are hard and a little cracked.
Now, how would go about recambering the suspension in the back? I've got a chilton manual handy.
Old 10-18-2004, 05:47 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
look on ami's 4th gen website to see about using longer bolts and washers to change the camber of your wheels. its fairly simple, you just move the upper control arm out further.
although i would say that if everything is stock, a stock component is worn beyond its life, and thats whats making you have bad camber. you can fix it with the washers and longer bolts, but you will only be covering up another more serious suspension problem
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
