Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-16-2004, 03:30 PM
Rose00Gray Rose00Gray is offline
keyless entry
can anyone tell me how to program my remote to a 95 firebird?
Old 10-16-2004, 03:37 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: keyless entry
Welcome to the forum and let me know if you need anymore info.
Programming procedure:
Ground the program input line by connecting a fused jumper at the Data Link Connector (DLC) from terminal "G" to terminal "A" (note: use terminal G and A for pre '95 12 pin DLC. A is the top right pin and G is the bottom left. Use terminals 4 and 8 for the '95 16 pin DLC. The 16 pin DLC connector is numbered top left (1) to top right (8) and bottom left (9) to bottom right (16) ). The Receiver will cycle the Door Lock Actuators within one to three seconds to acknowledge that the Receiver is in the "PROGRAM" mode.
Press any button on the Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Press any button on the second Transmitter once. In response, the Receiver will cycle the Door Lock Actuators to acknowledge that a transmission has been received.
Remove the fused jumper from the DLC and verify system operation using all three Transmitter buttons.
Important
Always program both Transmitters when replacing a lost or damaged Transmitter. The first Transmitter Code programmed will always be in both memories until a second Transmitter is programmed within the same sequence.
The Keyless Entry System will not be operational if the program input line is left grounded.
Program only one vehicle Keyless Entry System at a time. If multiple vehicles are being programmed in close proximity simultaneously, it is possible that the same Transmitter could be trained to more than one Receiver.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-18-2004, 02:09 PM
Talking keyless entry
Thanks sooooo much!!!!!
Old 10-18-2004, 07:55 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: keyless entry
No problem, Glad to help.
Old 11-03-2004, 12:54 AM
Great-King-Rat Great-King-Rat is offline
Send a message via MSN to Great-King-Rat
Haha...wow. I didnt know it was that complicated to do such a thing...
Old 11-07-2004, 05:53 PM
gwally54 gwally54 is offline
Re: keyless entry
Need help programming remotes for '98 WS6.
Can anyone help, please.
Old 11-09-2004, 05:18 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: keyless entry
Sorry I missed your post til now but here are the 96 + Keyless entry programming instructions. If you have any questions after reading these instructions please feel free to ask and welcome to the forum.
Turn ignition switch to OFF position.
Remove RADIO fuse 17 from fuse block.
Cycle ignition switch from OFF to RUN three times within five seconds until the door locks and the hatch release cycle, indicating the Body Control Module is in the Programming Mode.
Press and hold BOTH LOCK and UNLOCK buttons on remote control door lock transmitter for 16 seconds.
Door locks will cycle once, confirming the transmitter code is programmed. The door locks must cycle completely to unlock before proceeding.
Any transmitter code that was previously programmed has been erased.
Body Control Module is now programmed to remote control door lock transmitter.
When programming the Body Control Module to match remote control door lock transmitters, the first transmitter code matched will be stored in memory unless a second remote control door lock transmitter is matched at the same time. If programming the Body Control Module to match a second transmitter, repeat step 4. This must be done before the RADIO fuse 17 is reinstalled.
Ignition switch to OFF.
Reinstall RADIO fuse 17 to fuse block.
NOTE: Always program both transmitters when replacing a lost or damaged transmitter. The first transmitter code programmed will always be in both memories until a second transmitter is programmed within the same sequence.
Old 11-09-2004, 09:26 PM
tomahawk tomahawk is offline
Re: keyless entry
is it absolutely neccessary to use a fused jumper to program the keyless entry? if so i guess im off to buy one cause i need to reprgram mine.
Old 11-09-2004, 09:47 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: keyless entry
a paper clip will do or any wire will do but if you want one any auto parts store should carry them.
Old 11-09-2004, 09:51 PM
Re: keyless entry
ok thanks
Old 11-12-2004, 01:03 PM
sg1021 sg1021 is offline
Banned
Re: keyless entry
Spam not allowed
Hypsi87
Old 01-13-2005, 03:59 PM
pagan_princess's Avatar
pagan_princess pagan_princess is offline
Send a message via Yahoo to pagan_princess
Re: keyless entry
I'm wondering if my 95 formula has keyless entry,(it has power everything)
Any one know how I can tell?, I'd hate to waste good ebay money buying a remote if it does'nt.
Thanks in advance
Old 01-13-2005, 04:04 PM
Re: keyless entry
use the directions above that are listed to program a remote. if the door locks cycle then you have keyless entry. i think it was a standard option. just use a paperclip to connect the A and G holes.
Old 01-13-2005, 08:24 PM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Re: keyless entry
Thanks in advance
You can buy a keyless entry reciever box off ebay for pretty cheap even if you don't have it and on 95 models its a direct plug in install .Taked maybe 15 minutes and saves you the trouble of splicing in a aftermarket unit. Good Luck hopefully you won't need it, Also welcome to the forum.
John
Old 01-15-2005, 08:03 AM
f_bodymom f_bodymom is offline
Send a message via Yahoo to f_bodymom
Re: keyless entry
Wow, the diagram makes it helpful. I was wondering how you programed those.
Closed Thread
