rough running blazer
my 95 blazer has a jerky miss. i've replaced plugs. wires, rotor, dist. cap. took it to a local mechanic to be checked, he replaced the egr valve[claimed it had the wrong part number on the old one] anyway it did'nt fix the problem. he told me he thought the computer could be the problem. the truck runs better with the egr unplugged, but it still has the jerky miss. the miss occurs when your at a steady speed only, if you accelerate it runs fine.when the egr is plugged in it misses alot more but runs ok when i accelerate. there is no check engine light coming on, so i'm stumped as to whats causing this problem. can anyone please help? do you think it is the computer? any ideas would be appreciated. its driving me crazy.
Running rough
I am having the same problem with my truck. Had it checked out today, possibly the cam shaft sensor but more than likely it is the fuel injection system. Repleaced the egr on Tuesday and it did not help any. I am going to put both in next weekend. Is your truck running rich, smell gas once in awhile or carboning around the exhaust tip?
Re: Running rough
Re: rough running blazer
Your description sounds as if the problem is ignition.
I would recheck my work. 1. Is the cap seated properly? 2. Are all the wires seated in the cap and on the plugs? 3. Are your wires not intertwined where you could be inductively coupling into another wire? |
Doe sthe truck idle properly? Does the truck not start all the time and will sometimes take extended cranking to get it to fire up? Also, search the forums for CPI injector checking if you have the Orange Vortec plate on top of your engine. |
Re: Re: rough running blazer
1.) Clean and reinstall your EGR valve with a new EGR gasket.
2.) Remove the IAC valve and clean it with throttle body cleaner, scrub it with a tooth brush and get rid of the carbon and rinse it again with the TB cleaner. Reinstall and your idle problem should be fixed. Also, consider doing a fuull tuneup if you haven't done so including: Cap & Rotor Spark Plugs Air Filter Fuel Filter PCV Valve. |
Read my whole reply.
I also said to clean the IAC valve. |
