Old 10-16-2004, 03:08 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
turns over, but no start
1995 blazer, turns over but no start??? i have spark. just changed fuel filter. just had a tune up 2000 miles ago. what do you think?
Old 10-16-2004, 04:10 PM
Mikado14 Mikado14 is offline
Re: turns over, but no start
When you first turn the key on, do you hear the pump running?
Old 10-16-2004, 09:28 PM
bamabug bamabug is offline
The easiest way to check the fuel pump is to take the line off of the back of the fuel filter and get someone to turn the ignition on. Make sure you have something under the fuel line to catch the gas.
Old 10-18-2004, 06:44 PM
update. I jumped my car today with my brothers mustang. started right up. i let it run for 15 mins. then turned it off, to see if it would restart on its own. i tried and now, nothing happens at all. before i would hear my pump sending fuel and the car would turn over. now. i hear nothing and nothing happens when i turn the key. not even a sound. everything still works in my car. windows, radio, dash lights. suggestions?
Old 10-18-2004, 07:05 PM
i just went out to my car and tried to start my car. just to see what would happen. now, i can hear the fuel pump sending, but my car still doesnt turn over....
Old 10-18-2004, 08:40 PM
Clean the battery terminals and while you have them off check the voltage.
Old 10-18-2004, 08:47 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yea, sounds like the pump is not getting enough power to keep up the right pressure.
Seeing when you got jumped it worked, your battery is the problem. Time to replace it with a fully charged battery.
Or at least charge the one your have.
Old 10-19-2004, 08:27 AM
Re: Re: turns over, but no start
Now i have a different problem. I tried to jump start my car last night to bring it to my mechanic. and i was unable to jump start it. i can hear the fuel pump working, but it doesnt turn over....
Old 10-19-2004, 10:47 AM
Can you hear the solenoid engaging on the starter?
Old 10-19-2004, 12:01 PM
no. the only thing that i hear is the fuel pump. when i turn the key foward to start the car it does make the clicking sound. everything in my interior still works too...
Old 10-19-2004, 03:31 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: turns over, but no start
Pop another battery in and see if it starts.
Chance are yours is shot and won't even accept a charge again.
