Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 10-16-2004, 01:20 PM
blazr67 blazr67 is offline
Post fuel pump
I've replaced the fuel pump in my 97 sierra two times with in the last year .
I,ve replaced the pump , and fuel strainer .
I ordered a new fuel sending assy. and when it gets here I'll be repacing the fuel pump again .
Keep losing pressure , any thing else I should look at ??
Also have replaced the fuel filter.
Should I look at the fuel regulator? ( where is it on a 5.0 ? )
Old 10-18-2004, 11:00 AM
sudsy49 sudsy49 is offline
fuel pump
make sure you clean out the fuel tank thoroughly and check for rust or contamination. I had a Caddy that would just quit, driving down the road! After replacing the fuel pump, filter, rebuilt carb, and ignition control module, I found that the tank had alot of crap in it that was getting sucked up onto the inlet strainer!
Old 10-21-2004, 12:38 AM
93silverado 93silverado is offline
Angry Fuel Pump
Just Replaced Mine Again I'm Looking At Either Changing Injectors Or Get Them Cleaned As There Are Screens In Them That I Think Are Restricted Inj Are Making A Clicking Noise.
Dealer Advised Me Not To Run Tank Down To Empty As Pump Is Designed To Use Fuel To Cool It Keep Tank At 1/4 To Insure Fuel Is Covering Pump So It Won't Burn Up Smart Design Duh!!!!
I Had Regulator And Everything Esle Checked Out All Was Ok, Parts Man Said Common Problem So Were Not Alone. Ron
Old 10-21-2004, 05:53 PM
Re: Fuel Pump
I called the dealer and am takeing it in monday.
Dealer said it might be the regulator .
I'll let you know.
It's realy starting to get me PO'ed
Old 10-30-2004, 05:46 PM
Re: fuel pump
had to replace fuel regulator .
truck runs good and isn't losing fuel pressure
