Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 10-16-2004, 12:30 PM
Vast Lane Vast Lane is offline
Angry irritating vibration
I have new tires on my 1999 K1500 Suburban. They have been balanced three times and I still have vibration between 60-72 mph.
before I purchased the new tires there was no vibration.
I have replaced the u-joints.
What's the solution?
Old 10-18-2004, 08:40 AM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
Re: irritating vibration
Did the shop use road force variation balance? That will pick up internal defects in the tires a standard balance will not detect. Double check with the shop and if they don't know what that is, go somewhere where they do.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 10-24-2004, 04:05 PM
pennypicher pennypicher is offline
Send a message via Yahoo to pennypicher
Ya try another shop or you can dump some anti freeze in the wheel. This will fill in the uneven spots while the tire is rotating. Have friends that do it with big tires.
Old 10-24-2004, 06:07 PM
goinbig goinbig is offline
Send a message via AIM to goinbig
What kind of "big tires" do they do that on??
I've got 44" TSL's on one truck and 60" tractor tires on another. I wouldn't dream of putting any liquids in there. The only reason they ride rough is because they start to settle and turn "square" easily.
But ya, do what Grant said!!
Old 10-24-2004, 09:10 PM
They happened to be on a Peterbuilt truck. Fronts. Had a up down bumping. Too many Arkansas I 40 pot holes!!!
Old 11-03-2004, 05:14 PM
97integrals's Avatar
97integrals 97integrals is offline
tires
Old 11-07-2004, 07:19 AM
bigjayzway bigjayzway is offline
You don't have to put liquids in tires!!!! This will cause more problems in the end. If these are an oversized tire, then all they are doing is settling when parked as stated before.. Chec the tire pressure, they are suppose to be a lot higher than regular tires. Example most oversized truck tires will run around 65p.s.i.
