Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 10-16-2004, 12:27 PM
hothotrod hothotrod is offline
Send a message via MSN to hothotrod Send a message via Yahoo to hothotrod
Angry Strange cold starts
I have a 1993 mirage es coupe with a 1.5 for some reason it decided to start not wanting to run when its cold i have to hold the pedal down a bit till it is "warmed" up and then it will idle ok. This also seems to have caused a problem with completely stalling out. It has only done the stalling out once. I need to know if it is possible the TPS ( throtle position sensor) is going bad or maybe needs to be adjusted. Thanks for any information that would help.
Old 10-27-2004, 02:27 PM
jjautomotive jjautomotive is offline
Re: Strange cold starts
how many miles is on your car......
I also have same problem check out O2 sensors and possibly catalytic converter.... possibly clogged and may have ruined your o2 sensors ...my car same problem... but now over 1 year... now problem worse after detecting site of fault.... let me know if that is the situation.
Old 10-30-2004, 07:32 PM
miragenut miragenut is offline
Send a message via Yahoo to miragenut
My car has bout 140,000 on it i havent tried the catalytic it now acts like the Distributor is out again. i will look into the catalytic though thanks for the heads up. its been giving me fits.
Old 01-03-2005, 04:16 AM
)(-DR-Lucky-)( )(-DR-Lucky-)( is offline
I have a 92 Mirage 1.5 and i just joined the website. I am a mechanic for a living and know enough about these mirages. Ive had my 92 hatchback for 185k miles. The Cold start problems mainly persist of O2 Sensors. Also these little 1.5's get so many miles on them and the rings go bad it is common for a little gas to get by and gas foul ur plugs. Just a few pointers.
Old 01-04-2005, 06:27 PM
babybison babybison is offline
91 mirage hates MN winters
1991 Mirage 1.5L 160,000 mile won't start if temp is below 30 degrees F.
Bought it 3 monthes ago started every day till the first below 30 day. tried to sarted every day for a week nothing. First above 30 day started right up. Plugs are damp/wet and the engine cranks over like normal.
Have changed plugs, wires and rotor.
Car when runs has a slight lope to the idle but I am told this is normal for this car.
Any suggestions? Is the a sensor in the MPI that would shut the spark off at this temp.?
Thanks,
Jon
