Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-16-2004, 06:35 AM
george536's Avatar
george536 george536 is offline
head gasket!!!!
anyone in cali can help me change my gasket. people here want to charge 500+. ill be willing to drive to you guy's house and pay u.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-19-2004, 12:43 AM
george536's Avatar
Re: head gasket!!!!
anyone??? damn jake or kevin why couldnt you guys live in cali? hey kevin the house in front of me is for sell.
-1990 Eclipse GSX
Old 10-19-2004, 02:48 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: head gasket!!!!
How much
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-16-2005, 11:16 AM
Clipsa Clipsa is offline
I dont mean to butt in, but 500$ for the headgasket is not bad at all- I had 4 quotes- 3 were ridiculous they wanted 1200-1500$- so we went to the Eclipse Speciality shop- a local mechanic shop called Show Down (I live in Ohio) and they did the headgasket, waterpump and labor for $500. I got lucky- I had the headgasket replaced 2 weeks before and it started leaking again- the bolts were stretched- make sure you changed the bolts no matter what and get the head checked and machined- that is super important- I had it machined the 1st time but we did not changed the bolts because it was the 1st time ever unbolted- but they do stretch! Also use an aftermarket head gasket- the factory ones from what I hear leak a lot? Good Luck!
Old 02-16-2005, 11:23 AM
AF - Advisor
Re: head gasket!!!!
I run a stock headgasket. Seems to work fine even over 500 whp for many people. ARP studs are the key.
Kevin Jewer
