Old 10-16-2004, 12:40 AM
drifting box civic drifting box civic is offline
Send a message via Yahoo to drifting box civic
Having problems
with the car coil wire is giving both sides positive not getting any power to the fuel pump and ecu doesn't blink once when you turn the key tried changing main relay with another used one that works and tried changing ecu but so far still nothing
Old 10-16-2004, 12:58 AM
]{iwi's Avatar
]{iwi ]{iwi is offline
Registered User
Send a message via MSN to ]{iwi
Re: Having problems
anything at all happen when u turn the key could be ur ignition, check ur wireing and all grounds
Old 10-16-2004, 01:02 AM
Re: Having problems
It tries to start, what part of the ignition the key part or the coil?
Old 10-16-2004, 01:24 AM
]{iwi's Avatar
Registered User
Re: Having problems
key but if it trys to start its may not be in there
