Old 10-16-2004, 12:17 AM
perkyt21 perkyt21 is offline
Send a message via AIM to perkyt21 Send a message via Yahoo to perkyt21
Question 94 Eagle Talon
Im considering an engines swap to 2.0. My rigid 1.8 constantlly blowing head gaskets. Question is what all will be involved with this seeminglly simple engine transplante. thank you for any help
Old 10-20-2004, 08:35 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: 94 Eagle Talon
a lot more then you would think. you need to swap the wiring harness, ecu, motor mounts, all your engine accesories. and if you have an auto you need to swap your trans too. blowing headgaskets could be from a warped head. have you had it checked for flatness and cracks? i have a whole 1.8 that you could buy parts from the only thing bad is the block.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
