Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-15-2004, 08:52 PM
floridakid floridakid is offline
Car wont Start
Hey I had a bunch of problems with my 420a engine ending in the overheating and ending of its life. So i bought another one and put it
in my eclipse gs 95'. After hooking up all the wiring harness, and everything else, I havent been able to start it.
The engine will turn over, but im getting no spark. The book said it was this or that sensor but after changing them still no luck. I read a earlier article about changing ac condensor wires with the coil pack wires ( like the plugs) but I dont really know what they were talking about. I was hoping somebody could enlighten me to a solution, or a better explanation please.
Thanks alot.
Old 10-22-2004, 02:08 PM
riff22 riff22 is offline
Re: Car wont Start
coil pack is what took over a distributer
Old 10-28-2004, 01:58 AM
hellah fresh's Avatar
hellah fresh hellah fresh is offline
Re: Car wont Start
I got the same problem like u man.. i blew my motor so i got another 420a.. it started but after my dad shut it off.. it wont start agian... same like u no spark =\ its been 4 months already
1996 Mitsubishi Eclipse RS -Red ****UPDATE**** My car is no more! R.I.P. 12/12/05
Mods: 420a DOHC equipped with: bored 54mm throttle, 2.5" cold air intake, 2.5 chrome headers, 2.5 Down Pipe, 2.5 resinator, 5" 2.5 flared muffler, 2.5 custom piping, Megan front & rear strut, Megan rear lower tie rod, Monroe Shocks, Aerospeed coilovers
Rollers: 18" TSW Throphy / Pirelli P7000 225/40/18
Old 10-28-2004, 03:09 AM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: Car wont Start
ya sure you got EVERYTHING hooked back up? did somethin like that many years ago and learned fast...te he he
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 10-28-2004, 05:45 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Car wont Start
I know on the turbo motors the AC compressor and coil pack connectors are identical. A friend of mine did in fact mix them, and sure enough the car wouldnt start The NTs should have different connectors though, and the odds of the AC matching the coil pack on that harness as well have to be slim.
On a turbo car, there are only a few parts that will keep you from getting spark, NT should be similar. Crank/Cam signal, ignition drivers in ECU, ignitor pack, coil pack, plug wires, plugs. And all the wiring in between. I may have missed something but I Cant think of anything else right now.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-30-2004, 12:48 PM
talon77 talon77 is offline
Similar, but different...95 Eclipse
I just purchased a 95 eclipse, and its doing something similiar that I haven't been able to figure out. It will run for a little bit (10-15 minutes)..then just shut off. When I check the coil pack, its not getting any voltage (at the middle wire feeding the coil pack). Don't know if the coil pack is fed by the Cam Sensor, or the Crank sensor...or if there's something else I should be checking. Just frustrating... so any help and/or recommendations would also be appreciated.
