Old 10-15-2004, 09:43 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Unhappy Almost died... my car.
Weird problem today...
Car hasn't moved in a couple days, and it's been cold. Its like 30 - 40 here in Chicago. This morning when I was going to work, I shifted to 2nd, and the car almost died. The A/F gauge went full red, and the rpm dropped drastically. Engine was cold. I went to neutral, and revved. The car then seemed kinda loud and rough. Coming home after work then, it was fine. Problem here? Thanks
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-16-2004, 08:15 PM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
Re: Almost died... my car.
Cold start...usually the oil. You may just need a good tune up. It will probably be better to use a lighter weight oil or make sure your car is warming up properly. Cars are not designed to be started and driven immediately though most people do. Can't hurt to let the car idle for a couple of minutes before driving.
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 10-17-2004, 12:15 AM
coolguycooz coolguycooz is offline
Might have a messed up fuel pump. But yeah when its that cold idle it for atleast 10 min. Oil has to get liquady so it can lub your engine better. Dont stomp that shit as soon as you start the car.
Old 10-17-2004, 03:12 PM
david-b's Avatar
Dave is THAT guy
Thats what I thought with the cold shit. I'll jut have to let it idle a lil b4 going.
75 Monte Carlo
Old 10-17-2004, 05:52 PM
BlackEclipse97 BlackEclipse97 is offline
Banned
Send a message via AIM to BlackEclipse97
dirty fuel injectors? i dont know mine did something like that in the mornings at one point and i put some fuel injector cleaner in it and its a lot but my A/F guage didnt do n e thing like that so i dunno
Old 10-17-2004, 06:11 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
unless you have a wideband o2 a af gauge is mostly useless
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 10-18-2004, 02:43 PM
david-b's Avatar
Dave is THAT guy
I know the A/f with stock O2 is useless, but it only goes up when it feels like it want to die, like cold early mornings.
This morning wasnt as bad. I let the car warm up, then drove. Still felt like it wanted to die, just a little. A/F gauge was all the way up tho, not up and down like it should. Once i start going, then everything becomes normal.
75 Monte Carlo
Old 10-18-2004, 08:04 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
ECU will make the car run a bit rich on cold starts untill the temp gets above like 200 or something, like a choke function.
just let it warm up.
