Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-15-2004, 08:40 PM
tomsindahizouse tomsindahizouse is offline
Send a message via AIM to tomsindahizouse
Question Catalytic Converter 02 Sensor Wiring
ok, so i put on my headers and i had my exhaust on a paint can so i didnt have to disconnect the O2 sensor for the catalytic converter, and somehow the exhaust fell off the paint can and ripped out the pins from the plug...The problem is that there are four wires (four different colors) that run up into the car (OEM), and then there are three white and one black wire that come out of the O2 sensor...im guessing that since my catalytic converter is not OEM (its a cheap piece of shit universal one)
When they (the person who owned the car before me) put the aftermarket CAT on they also changed the O2 sensor, but the plug matched OEM and it wasnt a problem. Does anybody know anything about the wiring to the O2 sensor on a 2000 civic si. and yes i do have a helms manual. any help is greatly appreciated. thanks
2000 Civic Si
98 Civic Dx
Old 10-17-2004, 06:36 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Catalytic Converter 02 Sensor Wiring
Does the O2 sensor have a company name on it or anything, like NTK? And are you sure it's 3 white wires and not 2 white and 1 gray?
Old 10-17-2004, 09:57 PM
no, its definitely 4 wires... no name on it, or part number.
2000 Civic Si
98 Civic Dx
Old 10-17-2004, 10:07 PM
CivicSpoon's Avatar
There is no Spoon
No I ment 1 black, 2 white and 1 gray, not just 2 white and 1 gray; just wanted to see if maybe 1 of the wires was a light gray and you thought it just looked white.
Old 10-17-2004, 11:15 PM
that is probably what it is 1 black, two white, and 1 gray....i was under my car and it wasnt very bright....what else can you tell me about this setup?
2000 Civic Si
98 Civic Dx
Old 10-17-2004, 11:25 PM
CivicSpoon's Avatar
There is no Spoon
http://www.ngksparkplugs.com/techinf...200&country=US Look at the last one. Seems like the tricky part is figuring out which one of the white wires goes to to the white wire and the org/blk wire; I guess probably follow this if it helps: http://www.hybridautomotive.com/tech/o2/#one
Old 10-17-2004, 11:44 PM
THANK YOU SO MUCH...i didnt think anybody would reply to this one....i will try this tomorrow.
2000 Civic Si
98 Civic Dx
