Old 10-15-2004, 07:59 PM
gtmud gtmud is offline
dana 30 Front diff
Can anyone tell me were I can find complete instructions on how to rebuild a Dana 30 front axle in my 00' XJ. suspect the inner axle bearings (if thats what they're called) are bad in mine.Thanks.
Old 10-15-2004, 11:52 PM
JeEpBoY95 JeEpBoY95 is offline
Send a message via AIM to JeEpBoY95
Re: dana 30 Front diff
get a FSM they have a pretty detailed guide to rebuilding the axles. i had mine done by a friend because i didnt know how to measure backlash.
Old 10-15-2004, 11:55 PM
Candoo Candoo is offline
A good repair manual should have decent instructions, but if you don't feel comfy with it, it is best to let a shop take care of it. You have to be sure that the back-lash between the crown and pinion are set properly afterwards, or they will destroy each other in time. You can buy a complete rebuild kit (shims included), or buy the parts separately as you need them.
Mark
'87 Jeep Cherokee 4WD
4.0 ltr / Auto
243,000 km / 131,000 km on engine
If it ain't broke, don't fix it !!
If it's a Jeep, IT's BROKE, fix it !!
Old 10-16-2004, 01:07 AM
JDPascal JDPascal is offline
If you pull your axles again, take off the diff cover and drain the oil, you can undo the 4 bolts holding the side bearings in place. The carrier will come out with a little coaxing. Note the side where each of the bearing caps came from and catch the bearing races and any shims that come out. Keep the parts separate for each side. you can inspect the side bearings this way and if ok, you can roll the carrier back in without any need for adjustments by putting the races and any shims back where they came from.
Torque the bearing caps to the spec in your new manual add cover with RT, put in gear oil and your away.
JD
Old 10-16-2004, 04:53 AM
Cam7 Cam7 is offline
WWW.danna2.com or get the service manual.
Old 10-16-2004, 09:50 AM
Saudade's Avatar
Saudade Saudade is offline
I think Cam meant:
http://www2.dana.com/
Old 10-16-2004, 02:21 PM
It is www2.dana.com.Sorry Too early in the morning.
Old 10-17-2004, 04:45 AM
cdlabelle cdlabelle is offline
Check this link out pictures and all..
http://www.jeepaholics.com/tech/lrhubs/default.htm
Old 11-17-2004, 11:49 AM
sas47 sas47 is offline
I have the 2000 Cherokee shop cd that they use at the dealers.Send me your mailing address i will send you a copy(free). [email protected]
Old 11-19-2004, 06:54 AM
Thanks sas, I just had one downloaded to me. Looks like the diff is fine, the problem either lyes in defective hub assemblies or suspension problem. Just had it aligned, everything is good. New ball joints. Drives great, everything is tight, still cracks though on a slow mild to sharp turn. Still running with the frnt ds out, need to reinstall tonight.
Old 11-25-2004, 09:08 PM
Bushpilot1 Bushpilot1 is offline
Question Re: dana 30 Front diff
I can not seem to get the dana link to work for the diagram, maybe I just don't have enough computer skills to operate the dana site for the d30 diagrams & info for the rebuild. ANY help with this would be greatly appreciated
Old 11-25-2004, 09:11 PM
Re: Re: dana 30 Front diff
Would the 2000 disk help any at all with the info for the d30 for the 89 Cherokee XJ. Sorry if I sound stupid with this, but other that a 41 willy's, am new to jeeps & forums. Any help would be greatly appreciated since I recently bought an 89 XJ with about 240,000 on it & everything is kinda loose. (Shake,rattle n roll??) Please let me know, am almost bald :-) from trying to work on it.
