Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 10-15-2004, 07:34 PM
Hobbes's Avatar
Hobbes Hobbes is offline
The unusual suspect
Concerned about my '93 Supreme
A week ago when I started my car there was this high pitch hum coming from the car and now it's getting a little bit louder. I can place this sound from the rear where the fuel tank is. Could it be that the fuel pump is about to go on the fritz?
Old 10-16-2004, 08:14 AM
DIY Mechanic DIY Mechanic is offline
If you want to test the fuel pump, then ground the wire that appears to be hanging there, connected to nothing, between the air fiter housing, remote + terminal, and the cruise control vacuum module.
This procedure is outlined in the GM Manual as well as a Haynes manual.
Since the fuel pressure regulator is closed, the fuel is actually pumped back to the tank.
