Go Back   Automotive Forums Car Chat > Lincoln > Mark VIII
Old 10-15-2004, 08:33 PM
KrAzE KrAzE is offline
Shock Mounts Problem.
Ok, Ive had a lincoln mark VII for a long time now. Its been my first car and I still love it. I recently got ahold of a prime condition Lincoln Mark VIII. 1994. Blue and wood grain int. Canvas top.. its nice. Upon testdriving I only found one problem with it. A noise in the back sounding like something was moving around.
Upon further investigation I found that on both sides of the car. The shock mounts are out of the holes. If you need pictures just ask, but basically. Its a Hole with a rubber gasket and some type of sealent. The hole holds the top of the shock in with this piece that is shaped like a two washers on a pipe, the one lower being slightly smaller so it will "pop" into the hole.
Now the thing came out of the hole and I want to put it back. Without it resting in the hole the shock has no pressure.. its just sitting on the airbags.
Is this a major problem? Can I still drive the car until I can get it fixed?
Any way I can fix it myself?
Old 10-15-2004, 09:28 PM
ONEBADMK8's Avatar
ONEBADMK8 ONEBADMK8 is offline
Banned
$42.00 a shock mount.
1 hour job in driveway with hand tools.
Will not hurt anything but your ears if you drive it like that.
VERY typical of the Mark VIII.
Old 10-16-2004, 12:05 AM
Whew. Good to hear.
Ill get on that one asap.
Any other "common" problems I should look for?
In my mark VII the tranny went out (mostly my fault...) and I replaced the entire air ride system.. I currently dont have the car under any insurance.. but I still love it.
Old 09-27-2007, 05:55 PM
lincolnlad lincolnlad is offline
Re: Shock Mounts Problem.
Anyone know who carries those mounts mentioned above? I've got a '97 Mark VIII with blown rear-upper mounts. No luck finding replacements.
