Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-15-2004, 06:22 PM
red123 red123 is offline
Unhappy outside tempeture sensor
Does anyone have or know where i can get the part number of the outside temp senser located on the front driver side of the car down in front of the raditor. Also the best place to get one.
Thanks
Old 10-16-2004, 10:14 AM
Re: outside tempeture sensor
anybody here?
Old 10-17-2004, 11:09 PM
snowmant76 snowmant76 is offline
Thanks
the sensors are sometimes known to fall out of there holders and lean up aganst the radiator for a misleading reading. if you get down look up the air damn leading to the radiater the sensor is pretty easy to see. You should look at that first if it is just a misleading reading.
Old 10-18-2004, 06:39 AM
Mine is broken the sensor is still there. However it does not send the tempeter back to the display in side the car. Thats why i need a new one. I need part number or if someone has one for sale then let me know.
Old 12-30-2004, 10:58 PM
Viol8tor Viol8tor is offline
Lightbulb Re: Re: outside tempeture sensor
I can help you.
The Ambient Air temperature sensor (outside temp sensor) you need is part number 16169194, AC Delco part number 1571823.
You can get them for $12.22 at www.rockauto.com
The dealer will try to charge you about $25 dollars for it, which is about $7 ABOVE list..
Happy to help!
~Chris
Old 12-31-2004, 01:09 PM
GuMan GuMan is offline
Re: Re: Re: outside tempeture sensor
Originally Posted by Viol8tor
I can help you.
Happy to help!
~Chris
Check www.gmpartsdirect.com. They have GM OEM 16169194
for $9.24.
Old 12-31-2004, 01:13 PM
Re: Re: Re: Re: outside tempeture sensor
for $9.24.
Yeah, but the shipping is also much higher there. The minimum shipping charge is like $7.75 there, while it is only $4 something at Rockauto
Old 12-31-2004, 01:22 PM
RockAuto shows $19.83 with S/H to my address
in NC. GMPartsDirect shows $17.84 to my address.
Both using Ground residential delivery.
This is Rock Auto's lowest priced shipping method.
GM partsdirect does not base shipping price
on location, where Rock Auto does. Perhaps
Rock Auto is closer to your address and has
lower prices for shipping to your zipcode. Not
mine.
Old 09-23-2007, 05:09 PM
ODEANOK ODEANOK is offline
Send a message via AIM to ODEANOK
I just picked one up today at AutoZone for $16... they ordered it and it was here next day. Didn't fix my problem.... Mine reads about 20 degrees cooler than it should.... Anybody else have this problem? Thanks.
