Old 10-15-2004, 04:26 PM
Mr. Civic Mr. Civic is offline
name of 94 civic stock engine??
I just wanted to know wat is the stock engine for a 94 civic ex v-tech?
Old 10-15-2004, 04:27 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: name of 94 civic stock engine??
D16z6
Empty Pockets Racing Member #1
Old 10-15-2004, 04:37 PM
Re: Re: name of 94 civic stock engine??
thanks. I have another question, i am going to swap out my engine but idk if i should swap it for a b18 or a gsr engine?
Old 10-15-2004, 04:48 PM
GScivic7's Avatar
if you want to turbo go B18B, if you just want something that's decently fast out of the box go for the B18C
Old 10-15-2004, 08:42 PM
Masta's Avatar
Masta Masta is offline
Send a message via ICQ to Masta Send a message via AIM to Masta
i would go with the b18c1 motor. unless your going turbo, do what GSivic7 said.
1990 Honda CRX
Next Project: b16a
DREAMWORKS
Cardomain: http://www.cardomain.com/id/importscrx
Old 10-15-2004, 10:06 PM
95dxcivic's Avatar
95dxcivic 95dxcivic is offline
What if you go turbo with the gsr. Would a turbo b be faster than a turbo c1?
lowered on photoshop(its not that low, its not lowered at all!)
Empty Pockets Racing Member #4
Old 10-15-2004, 10:11 PM
GScivic7's Avatar
depends on setup, how much boost each is running etc. Off the line the B18 would get it if they were running the same setup. After that it's kinda up in the air. But the B18B is more boost friendly cause of it's lower compression.
Old 10-16-2004, 12:59 AM
Civic_D16Y5's Avatar
Civic_D16Y5 Civic_D16Y5 is offline
Send a message via AIM to Civic_D16Y5
gsr should be turboed
type r needs to be n/a
ls needs vtecand n/a
http://www.carsponsorships.com/scout/sponsor.php?id=737
GET SPONSORED, QUICK
Old 10-16-2004, 01:20 AM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
F**k LS/VTEC! Yeah I said it.
Old 10-16-2004, 01:28 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
The LS needs vtec and N/A? Umm, okay. Thats your opinion, the LS/Vtec is one option, regardless of whether you like that option or not. However, the LS is one of the most boost friendly honda motors, in that regard what it NEEDS is boost. Thats the general rule on why to go LS, go LS for boost. The lower compressor ratio is more turbo friendly. It's less prone to detonation becuase of this, detonation can kill a motor quick.
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 10-16-2004, 01:45 AM
94SolGrl's Avatar
94SolGrl 94SolGrl is offline
Honda GODDESS/Global Mod
Send a message via AIM to 94SolGrl Send a message via MSN to 94SolGrl
turbo a b18c... puts down nice numbers... just remember to rebuild it to a lower compression, like around 12:1... High comp + high boost = BOOM.
~*Emily*~
1995 Nissan 240SX - S15 whore
HOW TO POST PICS!
Old 10-16-2004, 02:25 AM
Honda God
Umm, I think you had a little bit of a typo there...
If he raised the compression that high, he'd blow the motor in spectacular fashion.
I think you ment Lower the compression, to like around 8.8:1.
EPR Member 4 Life
Old 10-16-2004, 02:40 AM
GScivic7's Avatar
Re: Re: Re: name of 94 civic stock engine??
werd...if I were to do a frankenstein I'd do a B20VTEC, but even with that I wouldn't be completely confident that my shit would be running 100%. Like I said before, B18B for turbo, B18C if you want something fast out of the box. Still boostable, but only good for up to 10 psi with GOOD TUNING, and depending on turbo.
Old 10-16-2004, 10:50 AM
94SolGrl's Avatar
Ummmm (DOHC) VTEC engines are usually running a 16:1 compression... 12:1 can handle 4-5lbs, and the magic number for high boost is 9.1:1. The LS blocks have 9:1, and the B20 blocks have 8.6:1.
~*Emily*~
HOW TO POST PICS!
Old 10-16-2004, 03:52 PM
GScivic7's Avatar
lol...are you serious. 16.1, you'd have to run like 150 octane gas.
DOHC VTEC motors have like 10.1 to 10.6:1 compression. With 12:1 compression you would be able to run like 2-3psi, so what's the point in even turboing it.
LS motors have 9.4:1(JDM) and 9.2:1(usdm) compression ratios. B20's have 8.8:1 compression, JDM and USDM.
B18B and B20 motors can handle nearly 12 psi. 12psi is going to do a whole lot more than 2-3 ever will.
You really need to get your facts straight before you start post BS like this, especially since you are a mod, should be setting examples for everyone else. Not posting false info like a newbie know it all.
