Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 10-15-2004, 03:30 PM
Kang114's Avatar
Kang114 Kang114 is offline
Limp clutch....
hey im wondering if any of you could help me out with this. so my clutch pedal is like completely snapped. its like a flabby cock. nothings wrong with the actual clutch because i was driving it hours earlier but now its like theres no push-back spring. it wasnt a gradual mishap either but now i cant relieve the clutch so i cant put it into gear at all so its just sitting in my driveway. any ideas fellas? hopefully its not too serious..
1993 prelude VTEC black, 20%tint all around, stock wheels/tires, weapon r intake, dc 4-2-1 ceramic headers, short shifter, Y.Paradas spec 2, THermal R*D ST exhaust
coming soon: lightweight 17" rotas,
Old 10-15-2004, 06:11 PM
G3_preludeSI G3_preludeSI is offline
Send a message via AIM to G3_preludeSI
Re: Limp clutch....
my friend ran into the same problem.......first check the clutch fluid, and see if its low.....if it is then just do the bleed thing like you would do with the brakes. this problem comes from bubles getting into the fluid for the hydrolic clutch sysyem, if u take the cap off the clutch fluid cap and bleed the system you will see the bubles comming up.......remember keep adding fluid as u do this......
Old 10-16-2004, 10:07 PM
LankorDie LankorDie is offline
I Hurd That If You Take A Pop Can An D Cut The Top Off It And Attach It To The Sping Under Your Petadl It Will Fix Your Problem
Old 10-17-2004, 12:11 AM
ProjectPhantom's Avatar
ProjectPhantom ProjectPhantom is offline
Re: Limp clutch....
the hell are ya smoking? dont bother posting if you're gonna be stupid. and learn to speak english...
back on topic....
same thing happened to me kinda... something got jammed and my clutch was stuck to the floor. dont ask me how that happened... still dont know myself... so maybe its jammed? or more likely its the clutch fluid....
Old 10-17-2004, 09:44 PM
Kang114's Avatar
yeah, so i checked my clutch fluid level and it was really really low. so i bought some more fluid and had my dad push the clutch in an out. bubbles came out but i could only add about maybe 2 tbsp before the bubbles stopped. im wondering where the lines are where i could drain some more air from????? because my clutch pedal still feels very spongy and weak even tho its driveable now.
Old 10-17-2004, 10:12 PM
Re: Limp clutch....
you have to keep doing the bleed thing, u cant just add fluid, theres a bleed valve on the front side of the tranny right next to the tranny mount, its covered by a black plastic thing, its hard to notice, just take the plastic off and use a, i think its an 8 mm bolt and just loosen it, andpump the clutch and then tighten it back up, add fluid, and repeat this untill theres absolutly no bubles left and the thing stays full
Old 10-18-2004, 02:47 PM
mikester_91 mikester_91 is offline
Re: Limp clutch....
How do you check the clutch fluid? Where's the resevoir at??
Old 10-18-2004, 08:40 PM
Re: Limp clutch....
the resevoir is next to the brake fluid one, its a bit smaller but its right to the left of it
Old 10-18-2004, 09:46 PM
Re: Limp clutch....
okay, facing the hood, where would it be located. On the right or left side? and a small resevoir?
Old 10-19-2004, 05:39 PM
crzyCollegeKid crzyCollegeKid is offline
Re: Limp clutch....
you might have to ask yourself, how did bubbles get in there?? you could have a problem with your clutch master and/or slave cylinders or the hydraulic lines.
Not-named-yet:
2011 Hyundai Sonata SE w/Sunroof and Nav in Iridescent Silver Blue Pearl
Claudia (traded-in):
2003 Mitsubishi Eclipse GTS: Pioneer Speakers All Around, Kenwood MP3 Deck, Clarion Equalizer, Boss 4ch. 800W amp, 2 Dual 12" subs with Dual 500W amp, XM Roady2
R.I.P. Jessica
1997 Honda Prelude: AEM CAI - Exedy Full Face Organic Clutch - XACT Streetlite 12.5lb flywheel - DC Sports Short Throw Adapter
Old 10-19-2004, 11:54 PM
Re: Limp clutch....
the bubles come from vibration and heat, the resivior is on the top right when u open the hood
