Old 10-15-2004, 02:47 PM
GTracer1618 GTracer1618 is offline
need new engine
hey everyone i have a 1992 3000gt SL and have a rod knock so im goin 2 need a new engine.. b/c i cant find a used engin e 2 put in im thinkin about puttin a vr-4 engine in b/c i no a good mechanic 2 do it 4 me.. wat all would i need 2 b able 2 do this?? lik changin the computer and all that, can i take it out of a used vr4 and put it into my sl? how expensive ect would this b? thanx chris
Old 10-15-2004, 03:20 PM
Igovert500's Avatar
blue + red light magnet
Re: need new engine
Do a search for "TT conversion"...
http://www.3sxperformance.com/faq/tt...partslist.html
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-15-2004, 03:54 PM
Re: need new engine
i found info 4 a tt conversion but not an engine swap any info will be GREATLY APPRICIATED!
Old 10-15-2004, 04:14 PM
Igovert500's Avatar
Re: need new engine
Well that would be the exact same thing...the vr4 engines are TT, so to drop a vr4 engine in would entail the TT conversion.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 10-15-2004, 04:16 PM
Re: need new engine
but if i put the whole vr4 engine into an sl wont i pretty much jus need the ecu and the guages and boost controller? i wouldnt need the oil lines and all because the r goin right into the motor so they would already be there..
Old 10-15-2004, 04:33 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: need new engine
But stuff like the pump won't be there so check out what you need that is not part of the engine.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 10-15-2004, 04:53 PM
Technical_Automan Technical_Automan is offline
Banned
why dont you just buy a rod and put it in?
Old 10-15-2004, 08:43 PM
StealthModifier StealthModifier is offline
Re: need new engine
check out nipponmotors.com ... im pretty sure they will have a DOHC N/A engine and a TT one
Old 10-15-2004, 08:45 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
the thing is, if you drop a VR4 engine in, you'll have a TT FWD car, and you'll then need to convert the AWD tranny into a FWD tranny. some have welded the VCUs, others have welded the planetary gear sets to make the AWD to FWD switch. So you'll have a pretty stout car, but you won't have the all wheel drive traction of a real VR4, nor will you have the 4 wheel steering of a VR4. There's a lot involved in doing this swap you wanna do...and since you're having a mechanic do it, i know labor is gonna be out the wazoo!
basically, you're probably just better off buying a VR4, for the money you'll be spending on this swap.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
