Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-15-2004, 02:25 PM
raymondvankuijk raymondvankuijk is offline
windshield washer container leaking
Added 1 gallon to 2001 Sub in washer container and light is back on... I do see some but not gallon amount of the fluid in garage. How hard to trace, fix?
Old 10-30-2004, 09:35 PM
JVT3 JVT3 is offline
Re: windshield washer container leaking
I had the same problem last year on my 2001,
Pulled the tank thinking it was cracked, but the rear pump housing was cracked. It just pushes in to the tank with a rubber gasket.
Replaced it for a few dollars with a generic at local auto parts store.
Old 11-01-2004, 07:02 AM
Re: Re: windshield washer container leaking
How hard is it to get to? Do I take out the battery? Thanks for the info
Old 11-01-2004, 08:10 AM
Pull the battery and the battery tray.
You will need to remove the plastic retainers on the
inner wheel well liner to ger to some of the bolts that hold the tank.
Also, make shure to check the plastic lines coming from the pumps. I had one that was rubbed thru and splice it with some vaccum hose and clamps.
About and hour job.
Good Luck!!!
Old 11-01-2004, 08:32 AM
Will try, thanks a lot.
