Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-15-2004, 10:53 AM
tsi95 tsi95 is offline
Unhappy Check engine light
My check enginge light wont go away. We used the scanner and it gave the code p0505. that code was for the IAC motor. I replaced it and it still the check engine light comes on. Does anyone know what else might be the problem?
Old 10-15-2004, 12:40 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Check engine light
I'm too lazy to read the whole thing but here is a LONG article about idle surg (normally associated with CEL p0505)
http://www.dsm.org/how-tos/tttt/tttt3.html
You might want to check this out also:
http://www.dsmtalk.com/forums/showth...ighlight=p0505
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-18-2004, 10:43 AM
Hey, Thanks for the info i'll try it out, and tell how it ends up.
Old 11-05-2004, 03:20 PM
i havent been able to do the steps that the website said, but now my car rpm's are going up and down when idle.
