ACT Clutch
If I have plans of getting a turbo, is an ACT Performance Clutch Kit w/ a heavy duty pressure plate and a 4 pad race disc good enough?
Before I get the turbo, will I notice a difference in performance w/ this clutch? I drive manual pretty well, but will I have trouble initially driving becuase its a racing clutch? |
Re: ACT Clutch
There is a torque limit to each of the ACT clutches, depending on what stage it is. As long as your turbo does not exceed these limits, you should be fine. If you don't know what it is, then either ask the seller or check with ACT.
You shouldn't notice a difference unless you also lighten the flywheel at the same time. Otherwise it's essentially the same as stock.
![]() 1993 Mazda Rx-7 Touring Ricer Extraordinaire |
