| COMPLETELY off-topic Talk about anything other than cars. But you can't be mad and angry in this forum! |
Yeah, so I'm sitting at work right now waiting for my roommate to get done with his work so we can go home. I was screwing around on our Mercedes Benz diagnostic manual and stumbled across the work instructions on how to change spark plugs on the new SLR. Thought you guys might find it interesting. Seems pretty easy to me.
Replace Spark Plugs I. Remove Engine 1. Disconnect ground cable from battery 2. Disconnect main cable harness from engine wiring harness 3. Raise vehicle 4. Remove bottom engine compartment panelling 5. Remove tunnel covering 6. Drain coolant 7. Drain oil 8. Drain automatic transmission fluid 9. Remove air cleaner housing 10. Remove fan 11. Separate coolant lines (1,2) from charge air cooler 12. Remove rear muffler 13. Separate oil feed and return line of oil tank 14. Separate lines of crankcase ventilation system from fitting of oil tank 15. Remove oil lines to oil cooler 16. Detach shift rod at transmission 17. Unbolt ground strap at transmission 18. Disconnect electrical connections at generator 19. Disconnect electrical connections at starter 20. Disconnect 13-pin plug socket from automatic transmission 21. Detach fuel lines 22. Extract oil of power steering pump 23. Disconnect ground line at power steering pump 24. Detach return flow and pressure lines of power steering pump 25. Evacuate fluid of A/C system 26. Open refrigerant lines connection at condenser 27. Separate connection of A/C system at distributor unit 28. Open connection of coolant return line 29. Separate automatic oil line from automatic oil cooler 30. Place engine supporting device underneath and align 31. Remove rear engine mount 32. Remove propeller shaft 33. Place the transmission jack underneath the rear axle center assembly 34. Detach steering shaft with universal joint at steering gear 35. Unscrew bolts from engine support bearing 36. Lower drive unit 37. Disconnect heater hose at firewall 38. Disconnect connection line of activated charcoal canister from compressor 39. Slowly lower the drive unit and guide it out of vehicle 40. Detach automatic transmission from engine II. Remove exhaust manifold with catalytic converter III. Unplug spark plug connector IV. Unscrew spark plugs V. Install in the reverse order
Re: Replacing spark plugs on a Mercedes McLaren SLR
Oh that's not too bad.
Suck shit.
Or just buy a new car.
![]() (\__/) (='.'=) This is Bunny. Copy and paste bunny into your (")_(") signature to help him gain world domination |
LOL!!!!
However try asking a new V6 Toyota Camry or Lexus RX330 (harrier) owner how they change thier spark plugs. For the front 3 its pretty simple. Remove engine cover. Change spark plugs. For the back three its a bit more involved. Remove engine. Change spark plugs. The Current model Ford Mondeo is the same, and Iv seen an older model Jap spec Mitsubishi Daimante that looked like it had the same problem. And its not a new problem either. I know theres at least one generation of Corvette that requires the removal of the front body shell, and anyone crazy enough to put a V8 into a Holden Torana or Ford Capri will have to remove the engine to get to the back two plugs. But of course I would have expected better from a Mercedes, especialy one that costs as much as the new SLR!
Re: Re: Replacing spark plugs on a Mercedes McLaren SLR
spark plug races anyone? let's see which team can get it done the fastest..... world record so far... is 2 days!!!
let's see who can beat it!!!
"Who are we to judge those, when we ourselves are afraid to be judged." |
Fuck, and I thought the Silvia's plugs were time consuming!
How much for the SLR plugs?
![]() And to make this job even harder, absolutely NO AIR TOOLS are allowed to be used on the SLR. And for good reason, if bolt threads on any carbon fiber component are stripped, it must be shipped to Germany (maybe England?) to be re-tapped. We can't do shit to repair them at the shop. McLaren also wants all bolts to be torqued to the inch-pound. I would have liked to be the SLR tech but that thing just seems like a huge bucket of stress.
Any kind of composite material just opens up a whole new can of things to go wrong when fixing a car.
Are the Carbon fibre parts made by McLaren or Mercedes? or a 3rd party? If done even a little bit wrong they could cause lots of trouble. If of course they get it right (and given McLarens experiance I image they will) then they should have no trouble, and the Carbon parts will out last the steel ones. But they have to get thier fixings etc right!
Dang it, I want to know how much all that would costs done by you guys
![]() Name: Andy "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." - Albert Einstein (1879-1955) |
Sounds like a fun week-end project...well...maybe a few weekends
Like if you owned an SLR you would do that yourself...
If I could afford one of those, I wouldn't even wipe my own ass.
MAKE ART, NOT WAR |
hmmm... honda spark plug removal:
unscrew plug wire cover pull plug wires get "honda tool", ram down plug holes, remove plugs. replace plugs. replace wires. screw on wire cover just as tight or loose as you like. 20 mins max...... and no, I haven't looked around the truck enough to find out what's involved... the engine of my truck is as big as my entire freakin sol was... *sigh* |
i dunno if i believe it. thats just too crazy.
Co-Founder of AF V-Card Club 1999 Ford Mustang Cobra: Cobra R rims, Magnaflow CB. "no way man...i saw an LS1 fight godzilla and the LS1 beat godzilla and it looked in the air and was like what do you think of that god and god was like bring it bitch so they fought and the LS1 beat god now the LS1 is god because its the greatest thing ever." |
