Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-15-2004, 04:02 AM
BlackSpyder1998 BlackSpyder1998 is offline
Exclamation possible crankwalk
Hi guys I was reading the 1000 already asked question regarding ticking noise near the timing belt and it went into a possible Crank-walk. “This problem usually manifests itself as a ticking noise coming from the timing belt area, as the sensor is literally and slowly ground away by the crankshaft. Any such noise should be investigated right away to prevent serious problems” Is there other reason why there is ticking (knocking) sound coming from here. Also the noise comes and goes, and would this be a problem for having engine vibrations, belts squeaks when turning, and engine hesitatation when accelerate. I have a 98 GST AUTO.
will the a car run if it has crankwalk and what other symtoms will let you know you have a case of crankwalk
[IMG][/IMG]
Old 10-15-2004, 04:17 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: possible crankwalk
The only way to know is to measure it. There is a lengthy thread at RKO where I describe how.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 10-15-2004, 06:17 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
the engine will run for a certain amount of time. what happens is the main thrust bearing wears and it starts to wear on the crank sensor. eventually it'll ruin the crank sensor so the ecu won't know where the cranks is and it shuts down the engine. you'll have power and everything but it wont' start because the engine doesn't knwo when to spark, pop the injectors....and so forth.
95 Talon TSI AWD
97 Eclipse GST
Old 10-16-2004, 01:23 AM
So what do I have to measure or where can I find all the info. another my car is still under warranty but the dealer doesnt want to fix it until it is completly broken. and would this also be the reason my valve cover gets loose all the time.
[IMG][/IMG]
Old 10-16-2004, 03:58 AM
AF - Advisor
www.racingknowledge.org, in the DSM section most likely.
Kevin Jewer
Old 10-21-2004, 03:09 AM
joemathews's Avatar
joemathews joemathews is offline
I wouldn't see a correlation between crankwalk and your valve cover getting loose...make sure your VC isn't cracked near the bolt holes.
Many DSMers overreact thinking they have crankwalk. You may just be hearing ticky injectors or lifter tick. Try to see if the noise is indeed coming from deep in the timing belt area, or from an injector or the valve cover. Put a screwdriver on one of the injectors and see if you feel a vibration when the ticking happens...
1996 Eagle Talon
Old 10-21-2004, 12:01 PM
GSTRacerNVUS GSTRacerNVUS is offline
Re: Re: possible crankwalk
There are too many things that tick and knock in there that create a constant state of paranoia.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 10-24-2004, 01:59 AM
EclipsNgirl EclipsNgirl is offline
Send a message via AIM to EclipsNgirl Send a message via Yahoo to EclipsNgirl
My car had cw when I bought it from the dealership. I drove on it for 1 1/2 years and it was still going strong when I took it to the dealership. The dealership can not tell you that they will fix it once it goes completely out...that could be tomarrow, that could be a year from now. Consider yourself lucky if you find a dealership that even knows what CW is. I printed up over 300 pages to prove to them what it was and what causes it-just incase they tried to deny me. They replaced my engine with a short block and about 3 months later I was redoing the engine myself. 2 months ago I decided I'd had enough of the 7 bolt CWing POS and put a 6 bolt in it and was done with it. Good Luck.
98 Eclipse gst-race ready
95 Eclipse gst-stock
92 Eclipse GST-parts car
91 Talon tsi RWD
87 Conquest-our new baby
Old 10-24-2004, 02:19 AM
AF - Advisor
Same thing here. After 3 7 bolts I gave up and went 6 bolt. Cases like ours are really rare though. Most poeple think they got crankwalk when they really just ran out of gas or something.
Kevin Jewer
Old 10-24-2004, 04:48 PM
If you want to here rare...check this out...My 98 GST had CW, my 92 1.8 Eclipse had CW (rare) and my 91 Talon TSI AUTOMATIC-yes you heard right, had CW...I guess I just attract CW in cars
91 Talon tsi RWD
Old 10-24-2004, 06:25 PM
george536's Avatar
george536 george536 is offline
Re: Re: Re: possible crankwalk
cw loves you.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 10-25-2004, 05:27 AM
Well guys I’ve being having many problems with my car here’s a couple of them. 1. Loud ticking (knocking) from the backside of the timing belt cover. 2. Rough idle it would go up and down and the car would shake "vibrate" this I already fixed it was the spark plugs that I put on. I put in the BPR6ES instead of the stock BPR6EKN, but I went and bought the stock ones and the car idles fine now. 3. Car died out during the rain here in California couple of days ago. I took the battery out and took it to AutoZone to get it tested and it charged up fine until they put a load on it and it would drop to 8.6 so I put in a new battery and car start up fine. 4. The stupid "service engine soon" light turn on so I need to get that diagnosed to see what it is. 5. Poor transmission shifting (auto) 6.when slowing down and accelerating the engine kind of jumps I think it might be a broken engine mount. 6. Squeaking belt only when car is cold and its louder if I turn the steering wheel but the noise goes away when the car is warmed up. Besides all this my car is still beautiful and fun to drive but with all of this I’m really disappointed with it especially with the stupid leaking roof.
[IMG][/IMG]
Old 10-26-2004, 12:58 PM
Re: Re: Re: Re: possible crankwalk
Originally Posted by george536
cw loves you.
Just like a fat kid loves cake
Symptoms of CW-since you're so worried about it:
-Clicking or ticking coming from the lower timing belt area.
-RPMs drop when pushing the clutch in
-Poor clutch engagement/disengagement results in some gear exhanges grinding, or being blocked out.
-Car won't start, and you've ruled out all other causes, this is probably your Crank angle sensor has been sheared off.
-You keep throwing belts because your crank pulley gets pushed out of alignment when you push the clutch in.
-Clutch pedal sticks down during hard left hand turns.
You might want to check your crankshaft endplay. The normal specs are (0.0020 to 0.0071) inches or (0.05 - 0.18) mm. The limit is: 0.0098 inches or 0.25 mm. That will let you know whether or not you are a CW victum. Check it and put your mind at ease.(or flip out and start crying-if that's the case)
91 Talon tsi RWD
Old 10-27-2004, 04:49 PM
joemathews's Avatar
My philosophy: drive the car. If you hear ticking, your clutch pedal sticks, or some other signs start to show up, try and fix them assuming they are other problems (i.e. lifter tick/master cylinder/etc.)
If it turns out your car is walking, who cares. Yea, it sucks, but just drive it until it doesn't drive anymore. When this happens, put a 6bolt in it. Problem solved, and you'll almost undoubtedly never have to deal w/ it again.
This was my biggest fear about buying a turbo DSM...but now that I've bought one, I have no doubts I made the right choice. This car is worth putting a new engine in, if it comes to that .
1996 Eagle Talon
Old 10-27-2004, 05:31 PM
2of9 2of9 is offline
how do make the engine "anti" crank walk? can you replace the crank with a performance crank or something??
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
