Old 10-14-2004, 09:31 PM
uncutnick3kgt uncutnick3kgt is offline
Send a message via AIM to uncutnick3kgt
just full of weird questions
hey everyone i asked this in w3si.org and i thought y not in here 2... so i was wondering what everyone thought about a supercharged 3000gt sl..... anyone with an opinion or wants to chime in is welcome!
Old 10-14-2004, 09:34 PM
Mitsub3000's Avatar
Mitsub3000 Mitsub3000 is offline
Re: just full of weird questions
i got a sl and i think adding a supercharger to one would be pretty nice
famous last words: hey guys watch this
famous last words: i bet i can do that better
98 3000gt sl
Old 10-14-2004, 09:57 PM
StealthModifier StealthModifier is offline
yea, would be pretty nice, but too much.. i wish it was around 2 grand, but for 4 grand u could do a TT conversion or swap, give or take a couple grand
Old 10-14-2004, 10:01 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
gotta be carefull with that, you will get alot of "just turbo charge it" around here and 3si.org. infact we have a discussion about that going on right now under "questions about supercharging my 3000GT" why dont you check it out.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 10-14-2004, 11:48 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
thats were he just came from
Old 10-15-2004, 09:07 AM
yea i posted it in here cause i wanted ur opinions and then i went to w3si.org and posted it there to c what they had for opinions..... i know it costs about the same to do but it would be unique was my only point... and safer in the end...
Old 10-15-2004, 09:37 AM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
I dunno if it's really safer, cuz a bunch of people with the Knight Supercharger for the GT said that the damn thing either doesn't fit, and if u get it to fit, than it'll blow out ur engine in a few months... hopefully RIPP mods'll get a nice one goin for a DOHC like they did with the SOHC...
Old 10-15-2004, 10:27 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Re: just full of weird questions
tru, it probably blows out people's engines b/c they turn the boost up too much. with our NA engines, the compression ratio is 10:1, and that will only allow us to run about 7psi boost max, whether you turbo or supercharge it. However, the VR4 engine has a compression ratio of 8:1, which allows it to run higher boost. you do the math.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-15-2004, 11:49 AM
Re: Re: Re: just full of weird questions
Absolutely true, running boost on a 10:1 compression will risk blowing the engine, but then that only enforces my belive that turbo charging and not swapping the pistons is a bad idea. quite frankly I have turbo converted a few cars and this is the first time I see people turbo charge a car w/out swapping the pistons from the VR-4. afterall it is easier to turn up the boost on a turbo then a SC.
as far as the Knight turbo kit, its not that the engine blows cause of too much boost, these guys run it from 5 1/2 to 7 psi, the problem is the air/fuel management that the kit uses is really weak and I guess it fails after a while causing the cars to run lean and KABBBBOOOOOOMMMMMM.
the ripp mods kit will be the safest route, those guys put alot of effort into thier product and run test after test after test to ensure it wont fail but WILL THEY EVER FINISH THE DAM THING! thier kit for the DOHC is still in prototype phase, it'll be another year before they can say they found the right settings for "safe power"
it took them over 2 years to develope the SOHC kit but look at that kit! its bullet proof, effective and safe. so yeah supercharging will be awsome since it delivers maximum power at low band, in the street you can smoke from light to light, just dont mess with any VR-4s when you get to the highway.
Old 10-15-2004, 10:38 PM
yea i was looking at nights... and one from gtpro.com... idk what that 1 was didn't really look into it thought i would c what everyone had to say before i really did my research.....plus i mean i'm not the all knowing car expert but isn't 8:1 better than 10:1 compression anyways!!! isn't that like a big thing to change....or am i wrong again
Old 10-16-2004, 04:30 PM
Kris_873 Kris_873 is offline
From my understanding, which may be wrong also, basically higher compression = more hp. lower compression = ablity to run higher boost on turbo and sc. running boost with high compression takes the chance of blowing the motor. It all depends on the condition of the motor and tuning.
Old 10-16-2004, 08:44 PM
Whats the lowest compression u can get?
Old 10-17-2004, 01:43 PM
i think stock vr4 pistons are as low as it gets for our engines
Old 10-17-2004, 05:09 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
You can always have some custom made and its not much more expencive than buying them from a tuner.
Old 10-17-2004, 09:09 PM
Whats the lowest compression pistons u could make that would be safe? .. and is there any ratio of psi to compression?
