Old 10-14-2004, 08:52 PM
jmichal jmichal is offline
Question HELP! Still overheating!!!
Hey ? can someone please help? I have a '78 trans am motor (400) in a buick body, the car has always worked perfectly, other than minor repairs here and there. Suddenly, the car began overheating to the point it blew hoses, I had them replaced, the water pump replaced. Tried to drive it , still was over heating. I put it in a local garage, had the oil changed , the transmission fluid changed, the thermostat changed, and the radiator checked , and the head gaskets checked. Got the car tried to drive and it is STILL the same problem. Took it back to garage, NOW they tell me the plate behing the water pump is missing, but that you can't buy them. What is a lady suppossed to do? Is there a plate behingd the pump? And where can I get one? THANKS.
Old 10-14-2004, 09:03 PM
henrymv henrymv is offline
Re: HELP! Still overheating!!!
Try a local junkyard.....have you also had the radiator replace or clean...those old GM radiator where known for rusting....that rust/crude can getinto the engine and water pump and ruin it....your probably better off replacing it with a much better radiator if it has not been dealt with...
Old 10-14-2004, 11:20 PM
Thanks for replying.. the garage said the radiator is fine. At the junkyard.. do I ask for the 'plate behind the water pump'?
Old 10-14-2004, 11:24 PM
yes....besure to let them know exaclty which engine you have....
I take it you have contacted every parts store in your area? Did you have a NAPA Auto parts in N. Carolina???
Old 10-15-2004, 07:54 AM
AccordCodger AccordCodger is offline
How did this get in the ACCORD forum?
Old 10-16-2004, 02:01 PM
Talking Re: Re: HELP! Still overheating!!!
Yes , I have been contacting junk yards.. We do have a local Napa. Will try there immediately. Again thank you,
Old 10-17-2004, 02:37 PM
LEt me know what happens.....
