Old 10-14-2004, 07:06 PM
superman0604 superman0604 is offline
High and low crossover
My amp has Variable Low-pass 45Hz to 5kHz
Variable high-pass with INTELLi Q 10Hz to 10kHz.
How do I know where to set it?
We all have to learn somewhere.
Old 10-14-2004, 07:16 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: High and low crossover
what's the amp powering?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 10-14-2004, 07:18 PM
It is powering 2 kicker comp vr 12"s they are dvc 4 ohm. The frequency response is 25-500
Old 10-14-2004, 09:39 PM
sr20de4evr's Avatar
set it to lowpass, somewhere around 70-80hz
'01 Black Sentra SE
'05 Silver WRX STi
Old 10-14-2004, 10:04 PM
How do you know where to set it. I am trying to learn about this kinda thing. It would be a big help. THanks for the help so far.
Old 10-14-2004, 10:21 PM
sr20de4evr's Avatar
There's no real magic spot to put it, around 80hz for subs is just a guideline. Do you know what a lowpass filter does? If not then you might want to check out www.bcae1.com. If so I'll just go on. You basically want to set the lowpass as low as you can while still getting good frequency coverage. Your mids have a natural rolloff when the frequency drops low enough, you want to set your sub's lowpass high enough where it can pick up where the mids leave off, but not too high where the bass becomes directional and you can hear it coming from behind you. 80hz is just sort of a happy medium.
'01 Black Sentra SE
'05 Silver WRX STi
