Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-14-2004, 06:31 PM
BrianEclipse BrianEclipse is offline
rps at idle
sometimes when im at idle my rpms will pulse about 100-200 up and down from the 1k mark heard that can be normal but not sure. today it was doing that pluse but every once and a while randomly it would go up to 1400 rpm then back to pulse at 1100-1200. what could this be please give me some info.
Re: rps at idle
99 gs eclipse headers, catback, intake
Old 10-15-2004, 09:33 AM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: rps at idle
It is called Idle Surge.. the cause of it could be many things, cleaning the TB helped a bit for me. Search for idle surge for other stuff that could cause it. It is not going to hurt anything so i would not go change ever part that could be causing it. Not worth it IMO, unless you reallly cant live with it.
For Sale 98 Eclipse GS, 5 spd
Old 10-15-2004, 03:11 PM
TB? sorry im still learning. oh throttle body?
Old 10-19-2004, 10:02 AM
rs97eclipse1695's Avatar
rs97eclipse1695 rs97eclipse1695 is offline
Send a message via AIM to rs97eclipse1695
my eclipse was doing that too except mine was dropping to around 6-700 rpm.changed the plugs and wires and it stoped.dont know if that will fix yours but its woth a shot...not too expensive
Old 10-24-2004, 06:07 PM
v3rtikal v3rtikal is offline
Check your TPS sensor . Its usually the culprit of an idle surge. Either its dirty and needs cleaing or you need a new one. You can find it on the throttle body. Take an ohm meter to check it.
-v3rtikal
92 Eagle Talon FWD
5spd - NT
"Always do what you wish you could..."
Old 10-26-2004, 10:49 AM
GSTRacerNVUS GSTRacerNVUS is offline
Re: rps at idle
^^ Yes! Use an ohm meter... Don't try to adjust by just the screw on the front of it.
(yes I've made the mistake myself)
That's if that's the problem.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
