2 questions
ok first
the light on the drivers side door is out. is there an easy way to replace it or do i have to take the panel off to get to it? 2nd my rear side window on the third door is loose by the lock. the window actually vibrates when im driving. can this be tightened or should i go to the dealer?
1968 Camaro 327 1999 Silverado 1500 Z71 LT {o,o} |)__) -"-"- O RLY? http://www.cardomain.com/id/korndogg002
Re: 2 questions
Not too sure about the window but, funny enough my door light was out when I bought my Silverado. You have to remove the door panel to change the light. Kind of a drag but, it only takes about 7 minutes to pull the panel off. Let me know if you want to know how to do that.
A thought about your window see if you can change the pins that pivot the window in and out maybe you can put something in a little thicker in diameter?
2008 GMC ACADIA SLE Edition, 7 passenger model I AM Canadian!! ![]() |
Re: 2 questions
About your window. Go to the dealer if its still under warranty. I had the same problem about two weeks after i bought my truck, but my window fell out. It doesn't take them too long to fix it if they have the parts.
when I pulled off my door panel, some of those cheap plastic one way pins broke, I used a good quality puller (looks like a big shoe horn) Is there something I did wrong? And I know what your thinking " yea you did something wrong , YOU did the work!
Re: 2 questions
can i just take like the bottom part of the panel off to get to it or do i have to take the whole thing off?
Re: Re: 2 questions
Re: Re: 2 questions
1998 ECSB Z71
Whelen LED's Kenwood 2-way "BIG 3" 2500+ watt audio ![]() |
