Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 10-14-2004, 02:44 PM
fritcr's Avatar
fritcr fritcr is offline
Angry 90 Prelude Si Leaking coolant
My little Prelude is leaking coolant from a sensor or something that is bolted on the front of the intake plentium. It has 2 bolts that go through it and one electrical connection. Then it has 2 small coolant hoses going to it. I took it off and there is a plate on it and a cavity inside the plate. It looks like the coolant is just running through it for the heat? Anyway, there is a gasket that is all messed up on that and I don't know what I'm looking at to order a new one. Can I get just the gasket? or do I have to buy that whole part? I'm figuring it has something to do with idling because of the holes in the intake where it bolts on. It leaks antifreeze down all around the intake and smells alful.
Rob
Old 10-16-2004, 01:39 AM
drmeyers2001 drmeyers2001 is offline
Send a message via AIM to drmeyers2001
Yes-you should be able to get just the gasket. Just go to honda and they will have a picture of the whole assembly. Make sure you clean off both surfaces before you put the new gasket on or else it will still leak. Use a wire brush and sand off each surface.
