Old 10-14-2004, 02:10 PM
smith04 smith04 is offline
Thumbs down problems with fuel pump on 95 blazer
My husband has a 95 blazer. He put a fuel pump in it last night. He tested it before he installed it, and it showed that it worked. Well, after he got it put in and tried to start his blazer, it wouldn't work. No humming when he turned the key. He is beside himself, and wants to know if anyone has any clue of what to do to check for any other problems that the truck might be having.
Old 10-14-2004, 10:03 PM
modification_inc's Avatar
modification_inc modification_inc is offline
Send a message via MSN to modification_inc
Re: problems with fuel pump on 95 blazer
are the fuses good?
Old 10-14-2004, 10:08 PM
Mikado14 Mikado14 is offline
Re: fuel pump not humming
Also, check the relay. There is a test wire located near the relay that 12V can be applied to for checking the circuit.
Old 10-15-2004, 08:09 AM
Lar232 Lar232 is offline
Check the fuel pump relay. It's in the glove box on the 95 Blazer. I had the same problem, replaced the relay and it worked great.
Good Luck
