Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-14-2004, 12:31 PM
caesarhernandez caesarhernandez is offline
Unhappy Fuel Pressure Regulator
Hello,
i have a 1998 Jimmy and it always has a hard time starting in the morning or if it sits for over and hour or so, otherwise it starts fine.
My mechanic suggested to check the fuel pressure regulator first, since the part was cheaper, but he's not exactly sure where it is and I don't want to pay him to fish for it....can someone tell me where it's located?
Thanks in advance!
Caesar
Old 10-14-2004, 12:47 PM
Re: Fuel Pressure Regulator
..Oh and it is a fuel injected Vortec engine 4.3L 4x4
Old 10-16-2004, 05:51 PM
XtremeXP's Avatar
XtremeXP XtremeXP is offline
It's located under the top manifold that has vortec written on it.
Old 10-22-2004, 06:55 PM
rabbit2475 rabbit2475 is offline
Send a message via Yahoo to rabbit2475
if you have centrel port fuel injection it is intergrated with the injection system and cost about 300-500.00
Old 10-23-2004, 03:09 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You can replace the FPR itself on the injector, but I don't recommend it.
Oh boy, this is not good.
If you can smell gas, you have a leak.
Also, is your fuel smelling like gas and is thin? Is the oil level high?
Here is a link where you can see where the gas has washed the inside.
http://www.asashop.org/autoinc/feb2000/techtotech.htm
Here is mine when I swapped mine out. See the passenger side where the fuel has washed it gold.
http://www.s10forum.com/forum/showt...cpi+replacement
Get a new upper plenum gasket when you do this. You might want to have a new injector and fuel line kit (called a nut kit) so you can swap it out.
Buy the CPI injector off of ebay and the nut kit from your local dealer.
Also, get this fixed ASAP or it will kill your cat and blow your engine if the fuel thins your oil too much and you blow your lower end.
